Home > Faults & Fixes > Erratic revs & rattling noise
Murphyslaw
Ireland 2005 Range Rover Sport TDV6 HSE Java Black
Hi, hope someone can help on this one. I have a 2005 RRS 2.7 tdv8. Starts & ticks over fine. No warning lights on and plenty of power. I've just noticed when I'm deaccelarating or coming off the gas coming downhill, the Rev counter keeps fluctuating. I've also noticed, if you open the window a rattle sound can be heard to coincide with the Rev counter going up & down. And lastly, that same noise can be heard when I'm accelerating. It's like a metallic noise (sounds like a pulley rattling or something). It's quite apparent when u open the window but cannot be heard at all with window up. If I drive easy, it's not there, only under load it seems and lasts for about a second, goes and comes back again every 3/4 seconds. Help!!!....
Post #467110 Fri Jul 10 2015 10:11am
Sportyboy
Rattle revs
Hi I am having exactly same fault slight rattle can only describe it like a rattle chirping noise at random ranges car drives fine no fault codes just a very slight dip In revs when the noise happens I have had 3 mechanics look at it and not one can put finger on it one tho thinks possible sticky clutch bearing !!! In gearbox ?.. Mine won't do it from cold only after about five minutes ?.. Cannot be heard with windows shut but do see a very slight dip on rev counter Shocked Shocked please help
Post #467601 Wed Jul 15 2015 9:27pm
Murphyslaw
Hi sportyboy. That's for your comment. Sounds exactly the same issue. Funny u mention from cold. I have it to a mechanic yesterday & we realised it doesn't happen when cold. It's a strange one. My concern is the fact it effects the revs. I'm hoping it's not a fault around the timing area! I thought someone would nail this one straight away. Mines going into workshop next Monday.
Post #467625 Wed Jul 15 2015 11:05pm
Sportyboy
Well mine is due a timing belt but can't see it's that as it would so it all the time mine won't make the noise if I rev the engine stationary please keep me posted and all the best on a cheap fix Smile
Post #467636 Thu Jul 16 2015 8:07am
Bodsy
Site Sponsor
Check the live values. Possibly oil temp sensor. That causes the engine to stall and be erratic due to the changing fuelling strategy. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #467639 Thu Jul 16 2015 8:16am
Sportyboy
Thanks will get him to do a live data check Sad Shocked Question
Post #467894 Fri Jul 17 2015 10:53pm
Murphyslaw
Hi Bodsy. Thanks a million. I have it booked in next week for him to check. Will post asa
Post #467990 Sun Jul 19 2015 10:52am
Sportyboy
Any joy on finding the fault still scratching out heads here ?? Sad
Post #468412 Fri Jul 24 2015 11:38am
Sportyboy
Question Rolling Eyes Question any one have any Idea
Post #469068 Fri Jul 31 2015 8:24pm
Sportyboy
Murphyslaw did you have any joy finding the fault at all?? Thanks in advance
Post #469426 Tue Aug 04 2015 2:36pm
Murphyslaw
Hi folks. Still no feckin joy. The mechanic is scratching his head. I've even noticed one up for sale with a reduced price because the guy has the same fault. I'm not giving up tho. The lad looking at it is away until next Tuesday & is taking another look.
Post #469596 Wed Aug 05 2015 6:11pm
Sportyboy
Thanks pal keep us posted I'm sick of paying people to look at mine and all coming back with what I can call as guess work diagnostics next stop main stealers when I'm back off holiday Smile
Post #469600 Wed Aug 05 2015 6:37pm
Sportyboy
Big Cry Big Cry any joy on fixing the noise yet fella ??
Post #471123 Wed Aug 26 2015 1:34pm
Sportyboy
still no remedy
going to flush gearbox tomorrow only does it round town not on a straight long run ???
Post #479596 Thu Nov 12 2015 4:35pm
Murphyslaw
Hi folks. Still no resolve. I had g.box flushed & added Dr. Tranny. Had all pulleys & rollers & belts checked. Still none the wiser. It is such an irritating noise. I'm surprised no one has a solution as I've seen numerous RR for sale with this fault. i.e. It's obviously common. Gonna try a ford forum to see if they have had any experience.
Post #480520 Fri Nov 20 2015 6:05pm
