Home > Faults & Fixes > Erratic revs & rattling noise
gary3306
England 2013 Range Rover Sport SDV6 Autobiography Fuji White
I know you've said you had all pulleys checked, but my thinking here is possible alternator bearing or internals. Reason I say that is normally the rev counter feed is taken off the alternator. If the alternator is rough and the tacho dance coincides with the noise, then it's a possible.
Post #480525 Fri Nov 20 2015 7:05pm
Sportyboy
Noise
Yes I too changed my gearbox oil and it's still there although I'm convinced its gearbox related did find a forum that mentioned software problems on the early ones mine is 2005 doesn't do it on motorway only round town!!!! Rolling Eyes
Post #480526 Fri Nov 20 2015 8:05pm
Disco_Mikey
Um, the engine speed is read from the crank speed sensor Thumbs Up
Post #480532 Fri Nov 20 2015 9:08pm
gary3306
Thats fair enough, I wasn't aware the RRS took the feed from there. A lot of vehicles use a feed from the alternator, certain models of LR included
Post #480599 Sat Nov 21 2015 6:35pm
quadcrosser
Belgium 2008 Range Rover Sport TDV8 HSE Lux Stornoway Grey
Is it like my noise ?
Right hand turbo is bad ....
Post #481424 Tue Dec 01 2015 10:18pm
Smithy 09
United Kingdom 2012 Range Rover Sport SDV6 HSE Lux Orkney Grey
Hi there having same problem was thinking it was the talk converter
Post #488844 Wed Feb 24 2016 11:13pm
quadcrosser
So I sent the turbo for a full rebuild.
Still the same noise ...
Now I have found the problem : It was a cracked exhaust manifold.
One of the bolts broke inside the engine.
You need to take the engine out of it to reach it for a good repair , it really sucks !! Sad
Post #488849 Thu Feb 25 2016 12:21am
Murphyslaw
Ireland 2005 Range Rover Sport TDV6 HSE Java Black
Hi. No, the noise we are experiencing is that low, u wud struggle to record it.
The strange thing is, it doesn't do it from cold. For example, if I drive up the steep slip road on the way to work, it's perfect. But if I do it 10 minutes later when the engine has warmed up, it's there. Basically what u experience is on acceleration/ loading the engine, there is an almost misfire or hesitation & u can feel it thru the car. Strangely enough, passengers don't notice!
Post #490139 Sun Mar 06 2016 11:16am
