Home > Technical > Clicking noise |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 |
Have you checked there isn't a small stone in the tread of your tyre ???
Sat Jun 27 2015 6:23pm |
Simon B Member Since: 28 Feb 2015 Location: Southampton Posts: 43 |
Yes I've had a look at that but the noise is far too regular and mechanical sounding to be a stone, I just picking people's brains because I don't want to drive it and do more harm than good, Thanks anyway. |
Sat Jun 27 2015 6:45pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2792 |
Did you notice it from pulling away - had the same symptoms - it was a park brake clip. Does the park brake screech when put on or taken off ? 16MY Estoril Blue SVR.............
Sat Jun 27 2015 7:08pm |
Not that I've noticed, if I have the wheel off is this park brake clip easy to see? |
Sat Jun 27 2015 10:52pm |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
Is it worse when you turn and put more weight on that wheel ? Then could be wheel bearing - relatively cheap fix. I wouldn't drive too far like that. Get a shop to put it up on a lift - take a look at brakes , driveshaft etc . |
Sun Jun 28 2015 6:35am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Sounds like the noise my CV joint made when it started to die. Whip the wheel off and see if either of the CV boots is split. Do you know if a CV boot has been replaced in the past? 2012 SDV6 - it's missing a couple of cylinders
Sun Jun 28 2015 7:53am |
No it's not worse when turning or putting more weight on one side just constant all the time. I don't think he CV joint boot is split at all but it's my plan to have a proper investigation later on today. |
Sun Jun 28 2015 8:37am |
It's been in to Landrover and indeed it was the handbrake retaining clip broken. All fixed and good now. |
Fri Jul 03 2015 10:19pm |
Fri Jul 03 2015 11:25pm |
