Home > Technical > Clicking noise
Simon B
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Clicking noise
Hi guys I've got a loud clicking noise from my near side rear wheel. It happened all of a sudden on my way to work the other morning one moment it was fine the next this noise although the car still feels fine to drive,It sounds like the wheel of fortune being spun off of the TV or when a kid puts a piece of card with a clothes peg in the spokes of a pushbike,
Anyway it is speed related and I'm guessing it's a cv joint or driveshaft or something like that. Just wondered if anyone has come across this before and am I ok to drive it from southampton to Portsmouth about 25 miles to get fixed under my warranty. [/list]
Post #465903 Sat Jun 27 2015 5:41pm
rigsby
Have you checked there isn't a small stone in the tread of your tyre ???
It could be a cheap fix !!!! MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #465905 Sat Jun 27 2015 6:23pm
Simon B
Yes I've had a look at that but the noise is far too regular and mechanical sounding to be a stone, I just picking people's brains because I don't want to drive it and do more harm than good, Thanks anyway.
Post #465906 Sat Jun 27 2015 6:45pm
PEACHY
Did you notice it from pulling away - had the same symptoms - it was a park brake clip. Does the park brake screech when put on or taken off ? 16MY Estoril Blue SVR.............
Post #465907 Sat Jun 27 2015 7:08pm
Simon B
Not that I've noticed, if I have the wheel off is this park brake clip easy to see?
Post #465914 Sat Jun 27 2015 10:52pm
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Is it worse when you turn and put more weight on that wheel ? Then could be wheel bearing - relatively cheap fix. I wouldn't drive too far like that. Get a shop to put it up on a lift - take a look at brakes , driveshaft etc .
Post #465919 Sun Jun 28 2015 6:35am
Sounds like the noise my CV joint made when it started to die. Whip the wheel off and see if either of the CV boots is split. Do you know if a CV boot has been replaced in the past? 2012 SDV6 - it's missing a couple of cylinders
Post #465924 Sun Jun 28 2015 7:53am
Simon B
No it's not worse when turning or putting more weight on one side just constant all the time. I don't think he CV joint boot is split at all but it's my plan to have a proper investigation later on today.
Post #465926 Sun Jun 28 2015 8:37am
Simon B
It's been in to Landrover and indeed it was the handbrake retaining clip broken. All fixed and good now.
Post #466478 Fri Jul 03 2015 10:19pm
Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #466484 Fri Jul 03 2015 11:25pm
