Home > Maintenance & Modifications > EAS Calibration with IIDTool, but car is to low or not?
rhenus132
Germany 2006 Range Rover Sport TDV6 HSE Lux Stornoway Grey
i have used height adjustment with IIDTool, but i was not sure if the values was accepted, so i did it 2 times, and than i want make it original and now i am not sure was the original height because its always just an offset.. ok call me idiot...Smile
I found this:
These are the original baseline heights for your vehicle:
Original Standard height values Wheel Center to lower edge of wheel arch
Front (mm) 466
Rear (mm) 485
This is for normal height right? But when i measure with my car i measure something about 430mm...that means my car is too low from previous owner? And its normal that when the car is leveled that front and rear is not the same?
I measure from the wheel center, so it doesn't matter what wheel size right? Now i am using 20"
Please give me some advice to bring back to normal height...
Thanks
Frank
Post #464611 Mon Jun 15 2015 11:18am
Bodsy
Site Sponsor
Frank, follow the instructions in the manual for the IID tool, there is a calculation sheet in there. Follow it exactly and it will fix your problem. It evene mentions what the heights should be.
Wheel size will make no difference. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #464612 Mon Jun 15 2015 11:20am
rhenus132
thanks for fast reply...
but in the manual i found that the height adjustments as an offset will effect all heights, offroad, normal and access height...
so there is no problem when i lower the car maybe about 20mm with that offset and start the calibration?
Post #464613 Mon Jun 15 2015 11:24am
rhenus132
When I sit inside the car. Where is a b c d position?
Post #464627 Mon Jun 15 2015 12:55pm
Bodsy
Site Sponsor
Not being funny, but have you looked at the calibration sheet.......?
Standard ride height for RRS
Front 461mm aim for a tolerance of +- 10mm
Rear 465mm aim for a tolerance of +- 10mm
you have to calibrate left to right so that the heights on both sides are the same and then yoiu adjust the front or the rear to increase/decrease to get the heights correct.
Personally, I would calibrate left to right values (or right to left, it doesn't matter really) and then you should set the heights to factory and then adjust them all higher or lower as required to get whatever height you are looking for. Bodsys Brake Bible
See it HERE
Post #464648 Mon Jun 15 2015 3:41pm
rhenus132
Wer did you find this?
That document saying something else...466 and 485
ok i did the calibration and now i understand that the calibration has nothing to do with the height, its only to calibrate the sensors to each other. the final height has to be set at the end, right?
what height is acceptable? i think to low or too high is not good and can be dangerous...i like more low but i am afraid i will damage something, or will get an unstable car when driving on highway
i have measured from wheel center to wheel arch and have set front to 456 and rear to 460mm in normal position...[/quote]
Post #464707 Mon Jun 15 2015 8:29pm
Bodsy
Site Sponsor
Are you looking at the D3 spec or the RRS spec....? Bodsys Brake Bible
See it HERE
Post #464711 Mon Jun 15 2015 8:36pm
rhenus132
Range Rover Sport 2006 TDV6
Post #464712 Mon Jun 15 2015 8:37pm
Bodsy
Site Sponsor
You know what, I cant find it again. It's not in the newer manual..... Confused Confused Bodsys Brake Bible
See it HERE
Post #464720 Mon Jun 15 2015 9:05pm
PatGapInnov
Canada
There is an error in the IIDTool user manual and I will make the correction Bodsy's right:
To simplify matters, you could recall the original height backed up when the tool was first connected: IIDTool Menu->Save Restore->Restore Settings->EAS Calibration->Restore Original http://www.gap-diagnostic.com/
Post #464807 Tue Jun 16 2015 5:51pm
Bodsy
Site Sponsor
Thumbs Up Thumbs Up Bodsys Brake Bible
See it HERE
Post #464808 Tue Jun 16 2015 5:54pm
rhenus132
thanks a lot..!!!!
Post #464816 Tue Jun 16 2015 6:27pm
rhenus132
i have done all steps and now the failure is gone...
that heights are original...
i want to make it little bit lower.... is there any min. height which is still in range and safe?
Post #465743 Thu Jun 25 2015 8:42pm
Bodsy
Site Sponsor
drop it 10mm and drive. then drop another 10mm and drive, then drop 1mm increments until you get fed up with the ride and put it back to original... Wink Bodsys Brake Bible
See it HERE
Post #465746 Thu Jun 25 2015 8:47pm
PatGapInnov
Canada
Bodsy's spot on. Keep in mind that if you lower it too much, the access height will become unusable as in:
If values for the standard height are set too low, the vehicle may reach the bump stops in access mode: In this case the EAS ECU registers a bottomed out condition and enters ‘Extended Mode’ automatically raising the vehicle (to allow the vehicle to drive out of the bottomed out condition). http://www.gap-diagnostic.com/
Post #465755 Thu Jun 25 2015 9:12pm
