![]() | Home > Maintenance & Modifications > EAS Calibration with IIDTool, but car is to low or not? |
rhenus132 Member Since: 13 Jun 2015 Location: Kaltenengers Posts: 34 ![]() ![]() ![]() |
Frank, follow the instructions in the manual for the IID tool, there is a calculation sheet in there. Follow it exactly and it will fix your problem. It evene mentions what the heights should be.
thanks for fast reply...
When I sit inside the car. Where is a b c d position? |
Not being funny, but have you looked at the calibration sheet.......?
Wer did you find this?
Are you looking at the D3 spec or the RRS spec....? Bodsys Brake Bible
Range Rover Sport 2006 TDV6 |
You know what, I cant find it again. It's not in the newer manual..... |
PatGapInnov Member Since: 30 Jul 2012 Location: Montreal Posts: 42 ![]() ![]() |
There is an error in the IIDTool user manual and I will make the correction Bodsy's right:
thanks a lot..!!!! |
i have done all steps and now the failure is gone...
drop it 10mm and drive. then drop another 10mm and drive, then drop 1mm increments until you get fed up with the ride and put it back to original... |
Bodsy's spot on. Keep in mind that if you lower it too much, the access height will become unusable as in:
