Home > General > Warranty Direct.... |
steve2026 Member Since: 30 Dec 2009 Location: Glos UK Posts: 122 |
You could also ask for the crystal ball they use.
Wed Jun 03 2015 12:38pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Time/mileage stamps etc. can be stored with fault codes which may sometimes be able to give such an indication. NB: I'm not in any way suggesting that the OP isn't telling the truth. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Wed Jun 03 2015 1:32pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
If the repairing garage can't get any date/time/mileage info from the car, let me know. Be more than happy to plug it in and get that Info for you |
Wed Jun 03 2015 1:44pm |
RRSMike Member Since: 01 Oct 2014 Location: Fife Posts: 32 |
When the engine warning flashed up on the dash screen that would also store the mileage when it happened? If so it would show that it has not done 1 more mile since then.
Wed Jun 03 2015 2:08pm |
I can understand this showing up in the event of a complete failure, ( which is usually the only way warranty companies pay up ), but if they are saying otherwise, ( which they are ), how are they getting their info. How do they know that the turbos etc were gradually wearing out, and didn't just explode without warning. They must have some very clever inspectors working for them? 2005 Vesuvius 1st edition ( now sadly gone ). |
Wed Jun 03 2015 3:35pm |
As I say, I'm not saying that's the case in this case. I suspect it's just a case of anything to get out of it...
Wed Jun 03 2015 3:47pm |
From their final letter:
Wed Jun 03 2015 4:01pm |
PAS Member Since: 30 May 2014 Location: kent Posts: 70 |
!!!so if this is the case any turbo'd car with say a whistle to it ,it should have the turbo replaced as they would say it was the start of the problem,but the warranty won't replace it till it fails. Are we all supposed to check air filters weekly for signs of oil?also check inter cooler pipes etc,etc.Some mechanic's say you will get some oil in the cooler pipes ,some say you shouldn't,does anybody know what to do to check the turbo's if your not a mechanic..The majority of us do our weekly checks,if there nothing flagging up on screen ,as I say what else can we do.Hasn'tre have been cases on here where main dealers have replaced engines due to turbo failure,could this be used in some way to help your case |
Wed Jun 03 2015 7:16pm |
Tartan_rob Member Since: 03 Jun 2015 Location: Wiltshire Posts: 2 |
Warranty Direct - good luck.
Thu Jun 04 2015 1:56pm |
Perhaps Pete at Land Rover might ask his engineers how an owner is to check his turbo-chargers to avoid this situation.
Thu Jun 04 2015 7:25pm |
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 |
Has there been an update here from Mike?
Tue Jun 09 2015 8:27am |
CRC@LandRover Member Since: 20 Jul 2012 Location: Coventry, West Midlands Posts: 213 |
Hi All,
Tue Jun 09 2015 1:00pm |
thanks for replying pete |
Tue Jun 09 2015 1:45pm |
So basically, if the vehicle has been serviced/maintained in line with manufacturers schedule, and you have proof of such, and, you were experiencing no loss of performance, and, or, funny noises etc etc then it's their word against yours that the vehicle was driven on in a faulty condition, leading to the failure of certain components.
Wed Jun 10 2015 7:58am |
