![]() | Home > General > Anti roll bar bushes |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Hi I had the front changed at Land Rover dealer for £80 including parts and labour. Rear anti roll bar bushes can be seen from the rear wheel arch so should be easy to replace. |
Si-W85 Member Since: 22 Mar 2015 Location: Huddersfield Posts: 109 ![]() |
Hi thanks sorry I should have said it is on the front, do you know if it is a dealer only job or can I buy the poly bushes and either do it myself or pay the garage that I used to use for all the work on my previous car? If there is a tool that is required to remove the ARB bush housing then I doubt they will have it so won't waste mine and his time letting him do it you see. Thanks |
Any good mechanic will be able to replace them. Also I'd replace your drop links at the same time. Easier to replace if you have proper ramp. |
The ARB bushes are more difficult to replace if you have the dynamic ARB and this will put the price up a bit on the labour side but nothing silly. 2012 SDV6 - it's missing a couple of cylinders
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Nothing Silly? How about £300 Plus parts Main Dealer Price. That is ACE type with 3 bolts. My friend ,a qualified Mechanic could not get onto the rear bolt. Seems the older cars without ACE are easier. I think they only have 2 bolts each side itisme |
You have to lift the body slightly to do the bushes - hence it's not really a DIY job on the driveway like it is is for the D3 boys.
I will do the drop links at the same time thanks. How do I know if I have the dynamic ARB? |
If you have a Supercharged or a TDV8 then you have dynamic ARBs. 2012 SDV6 - it's missing a couple of cylinders
I think all HSE models have ACE,ARB itisme |
Oh looks like it is a dynamic ARB then |
Try an indie LR garage. The labour rate will be much lower and as most of the costs in the job is labour... |
i have just called a local indie garage they told me that it may need some packers that Land Rover released and quoted me for front and rear inc parts and labour £185 inc vat is it wise to have front and rear done at the same time? Thanks for your help |
I think the packers were done for the non-dynamic ARB on the D3. They should just be able to fit the new bushes alone.
Thanks for all your help much appreciated |
