Home > General > Anti roll bar bushes
Si-W85
Hi I have tried a search on this but haven't found what I am looking for so hoping somebody on here will be able to help. My ARB bushes are making an awful squeeking noise so I sprayed them with oil to check it was them and the noise went away for a day, anyway I know I will have to change them but can anyone tell me how easy/hard of a job it is as I am lead to believe on the supercharged you need a special tool to take the rear bolt out is this correct and if so is it a dealer job and how much? Thanks
Post #463920 Sat Jun 06 2015 5:52pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Hi I had the front changed at Land Rover dealer for £80 including parts and labour. Rear anti roll bar bushes can be seen from the rear wheel arch so should be easy to replace. Thumbs Up
Post #463923 Sat Jun 06 2015 6:43pm
Si-W85
Hi thanks sorry I should have said it is on the front, do you know if it is a dealer only job or can I buy the poly bushes and either do it myself or pay the garage that I used to use for all the work on my previous car? If there is a tool that is required to remove the ARB bush housing then I doubt they will have it so won't waste mine and his time letting him do it you see. Thanks
Post #463926 Sat Jun 06 2015 7:18pm
ABSport
Any good mechanic will be able to replace them. Also I'd replace your drop links at the same time. Easier to replace if you have proper ramp.
Post #463937 Sun Jun 07 2015 4:01am
The ARB bushes are more difficult to replace if you have the dynamic ARB and this will put the price up a bit on the labour side but nothing silly. 2012 SDV6 - it's missing a couple of cylinders
Post #463940 Sun Jun 07 2015 7:46am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Nothing Silly? How about £300 Plus parts Main Dealer Price. That is ACE type with 3 bolts. My friend ,a qualified Mechanic could not get onto the rear bolt. Seems the older cars without ACE are easier. I think they only have 2 bolts each side itisme
Post #463946 Sun Jun 07 2015 9:13am
You have to lift the body slightly to do the bushes - hence it's not really a DIY job on the driveway like it is is for the D3 boys.
Getting a main dealer to do it is just asking for your wallet to be spanked... 2012 SDV6 - it's missing a couple of cylinders
Post #463977 Sun Jun 07 2015 5:46pm
Si-W85
I will do the drop links at the same time thanks. How do I know if I have the dynamic ARB?
Post #464023 Mon Jun 08 2015 12:01pm
If you have a Supercharged or a TDV8 then you have dynamic ARBs. 2012 SDV6 - it's missing a couple of cylinders
Post #464027 Mon Jun 08 2015 12:30pm
harrygh60
I think all HSE models have ACE,ARB itisme
Post #464029 Mon Jun 08 2015 12:37pm
Si-W85
Oh looks like it is a dynamic ARB then Sad trip to the main dealers then Censored Big Cry
Post #464030 Mon Jun 08 2015 12:37pm
Try an indie LR garage. The labour rate will be much lower and as most of the costs in the job is labour... Whistle 2012 SDV6 - it's missing a couple of cylinders
Post #464039 Mon Jun 08 2015 1:36pm
Si-W85
i have just called a local indie garage they told me that it may need some packers that Land Rover released and quoted me for front and rear inc parts and labour £185 inc vat is it wise to have front and rear done at the same time? Thanks for your help
Post #464042 Mon Jun 08 2015 1:50pm
I think the packers were done for the non-dynamic ARB on the D3. They should just be able to fit the new bushes alone.
As for doing both ends at the same time, for £185 all in, I'd say you may as well. 2012 SDV6 - it's missing a couple of cylinders
Post #464065 Mon Jun 08 2015 5:17pm
Si-W85
Thanks for all your help much appreciated Thumbs Up
Post #464084 Mon Jun 08 2015 7:44pm
