Home > Technical > can I safely disconnect my MAF sensor(s)? |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
Really, that would suggest the valve is not, in fact, open then.
Thu Apr 23 2015 2:33pm |
No, I was referring to the fact that the valves appear to sit at 56% (i.e. partly open) but yet you have no symptoms of this. Visiting from DISCO3.CO.UK
Fri Apr 24 2015 12:49pm |
LFW- Have you ever monitored live EGR values on a TDV8?
Fri Apr 24 2015 5:04pm |
Afraid not. I would assume that they should all function in the same way - i.e. open at idle but should close once you apply throttle. They can't be intended to be open under load. Visiting from DISCO3.CO.UK
Sat Apr 25 2015 8:36am |
Err... Did anyone say the EGRs are open under load - I certainly didn't.
Sun Apr 26 2015 1:49pm |
Well, it is under some load, but obviously it's a grey area in such, literary, terms.
No, but, however controlled, it comes down to whether the circumstances are acceptable for the valve to be open so, in practice, it's sort of binary.
The IID shows both the actual and commanded positions for the TDV6 so I would have assumed, if they were command positions that they would be labelled as such but, that may well be the case. Have you seen anything of significance in any other live values yet? Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Sun Apr 26 2015 2:36pm |
ONE FOR THE NERDS
Tue May 05 2015 4:37pm |
The EGRs and TC are certainly very active there aren't they - and they do seem to correlate, in parts.
This is just the sort of thing I was wondering about the other day - Perhaps a button could be built in to the app as a sort of live value for this purpose?
And even more improvements coming soon including the ability to set live value and CCF presets Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Tue May 05 2015 5:18pm |
OK so had a go yesterday at some advanced data logging:
Tue May 12 2015 7:21pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8999 |
Interesting that the two EGR traces aren't exactly synchronous. I'd have thought they'd be the same all the way through. 2012 SDV6 - it's missing a couple of cylinders
Tue May 12 2015 7:57pm |
Thanks for the input.
Tue May 12 2015 9:16pm |
The red EGR trace seems to be slightly more "active" than the blue one, certainly it shows peaks in places that the blue one is flatter - admittedly these are 1 second differences so maybe that is within tolerances as it's usually within 5% of the blue one. One particular moment of interest is at 423s. They both close but the red one blips back open to 35% momentarily. 2012 SDV6 - it's missing a couple of cylinders
Tue May 12 2015 10:14pm |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 |
Interesting graphs and I will look for the same 'feature'.
Wed May 13 2015 8:21am |
Thanks for the comments gents. I was hoping Robbie might pick up on this thread!
Wed May 13 2015 9:00am |
