![]() | Home > Technical > can I safely disconnect my MAF sensor(s)? |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
I didn't know that you had taken it to Bristol Transmissions as my humble knowledge is eclipsed by their expertise; they are a good bunch who I have learned loads from. They know this box inside-out.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
Paddi, it might just be that this shunt is a "ghost in the machine" - a little foible that you never get to the bottom of.
The TC mode does change state when it has finished helping to heat-up the oil and it also allows the use of 6th gear too. The use of cruise control also changes the TC mode and strategy. ![]() How To - Battery & Quiescent Current Drain Testing Free Fault Code Reading For Established Members: Defender, FL2, D3, D4, Evoque, RRS & FFRR ![]() |
Point taken - but I'm not prepared to give up quite yet ![]() Last weekend I recorded another log whilst cruising along on the M25 and M2 and this time selected live values for: Accelerator position (2) Coolant temp Engine RPM Actuator supply volts (solenoids) Solenoid 5 pressure Solenoid 6 pressure Torque converter Transmission current gear The full pdf is here: http://www.rrsport.co.uk/gallery/albums/us...35_Log.pdf and a snapshot of one 'jolt' episode at 990 seconds is here:
On this log there two jolt episodes (TCC changes from closed to open to regulated and back to closed) at 990 seconds and again at 2063 seconds It is interesting that the actuator supply voltage is steady at about 13 volts but momentarily spikes to zero one second before the TCC unlocks. Solenoid 5 and 6 pressures are erratic all the time but drop to zero on the jolt. The accelerator position looks erratic even though I was holding the speed pretty steady (as can be seen by the steady RPM) One little detail to add is that on the return journey I used the trip meter to measure the distance between jolts and it was 20.3 miles between the first and second jolt and 20.1 miles between the second and third which is remarkably consistent n'est pas? What is rather frustrating is not having any 'control' data with which to compare the logs I am seeing ![]() Going to press on and record some further values not tried yet and them maybe, as Robbie suggested, take the information along to Bristol Transmissions again or my nearer specialist who are known and respected by Bristol. 2008 MY Java Black TDV8 HSE ![]() |
There is a one second gap in the gear selected line at the moment of the 990s jolt. Not sure if that is an artefact of the data plot or an indication of a cause. 2012 SDV6 - it's missing a couple of cylinders
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 139 ![]() ![]() |
This thread is probably past it's "Sell By" date. I had this issue as well, but on a Freelander 2 (PSA diesel engine). I would get random shunts, especially under light acceleration. Issue turned out to be related to the crankshaft sensor.......one of the sensor wires was chaffing against a metal bracket. This is the bracket to which the wire is secured en route to the crank sensor. With regards to disconnecting the MAF sensor......... if the MAF sensor should fail for any reason, the engine may run badly, or not run at all. Disconnecting the MAF would force the ECU to rely on the TPS for engine load sensing. Not the best for emissions and fuel economy, but at least it would get you home. |
