![]() | Home > Technical > can I safely disconnect my MAF sensor(s)? |
RRSTDV8 - so it seems your TC is working almost correctly apart from poor shift quality?
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
I don't know whether my TC is working properly or not. The whole drivetrain seems quite laggy at times. It feels like old fashioned 1980s "big turbo" response to the throttle; throttle pressed, nothing, nothing, woosh. I suspect EGRs but I have no error codes or other indications of a problem.
"As an aside, it is possible to calibrate the transfer box without a diagnostic tool of any sort. There is a "magic procedure" in the workshop manual."
Sorry - this is becoming a bit of a 'nerdfest' |
The speed can increase with the TC clutch unlocked - it's behaving as a traditional automatic at that point so you get a "slushy" response. When the clutch closes there is direct drive from engine to gearbox - effectively bypassing the TC as I understand it - in order to improve fuel economy and emissions. The EGRs opening at that moment won't be helping matters as the engine will be breathing "dirty" air just when you're asking for some performance.
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
I'm not seeing 0.2v voltage spike or really anything odd in the alternator trace.
Thanks for the input guys.
Well: as suggested - recorded another log in steady cruise conditions with different variables. My IID Tool doesn't offer me live values 'Clutches A,B&E' or anything else called a clutch so I just chose Solenoids 1 to 4 plus accelerator pedal position sensor 1, engine speed, EGR valve 1 and TCC. Edit: - checked the manual and it seems Solenoids 1- 4 are Clutches A, B, C and D + E respectively When the 'jolt' occurred I stopped the recording as soon as I could. You can see from the log linked below that the TCC went from closed to open and back to regulated starting at 656 seconds. But something odd was happening before that at 604 seconds. There were changes in solenoid pressures and although the engine speed was constant there were some odd changes in accelerator pedal position (but I don't think I was moving the pedal). http://www.rrsport.co.uk/gallery/albums/us...cruise.pdf What I am struggling to understand here is if any of the changes are causing the TCC behaviour or just reacting to it. To help with viewing on tablets - I'm attempting to attach here a snapshot of the log when the jolt occurred with the variables labelled so it makes sense to anyone who can't see the whole pdf on their device.
Be interested to see if both throttle pedal sensors show the same movement. It appears that the car is responding to what it thinks is a rapid application of throttle and is closing the EGRs and doing the stuff you'd expect it to do when you ask for some beans. I wonder if you have a throttle pedal issue...hopefully Robbie can make more sense of it than my feeble attempt |
"I wonder if you have a throttle pedal issue..."
Can you send me the full pdf and export the log as a CSV file so I can spin it in excel?
Some background reading:
Hi Robbie,
I've had a chat around and your issue has caused some head scratching. Current thinking includes a possible software glitch causing an erroneous command (I'm not convinced with this option), a mechatronic leak releasing pressure or a mechanical issue with a stator bushing changing the applied pressure.
