![]() | Home > In Car Electronics > Urgent Help Please Sat Nav Screen Not responding to Touch |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Where are you roughly? I am in Gaschurn, Austria and I have an IID Tool with me if that can help. |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 ![]() ![]() ![]() |
Hi mate, I'm in Tignes so a bit far for you but many thanks for the offer, what is an IID tool? |
Yep, 400 miles.
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Just an idea - try putting the passenger seat fully forward - disconnect & reconnect each connection at a time in the rear of the Sat Nav unit - never know it might reboot the system.
Cheers, will give that a go in the morning |
You need to do a hard reset..
Update, it is now responding intermittently but more times not, Cheers Flack will try the hard reset, |
Further update, I think it does not like the cold, lefts all day in the sun yesterday and worked fine every time, parked up for an hour and temperature had dropped to freezing and not working, will get it a thermal jacket!!! |
Well hard reset carried out but still not working correctly, I'm lost on this one! |
Sometimes some dirt can lodge inside the rim of the screen, this then stops it from responding to your touch, take the screen out and remove the screen bezel and check nothing is jammed in there, other than that you might need a new screen.
Hi Flack, many thanks for the advice, is there any instructions available on how to remove? |
Update, cleaned around the screen bezel, there was some dirt and some bits of grit in there, touch wood all working fine since, many thanks Flack |
