Home > In Car Electronics > Urgent Help Please Sat Nav Screen Not responding to Touch |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
Where are you roughly? I am in Gaschurn, Austria and I have an IID Tool with me if that can help. |
Sat Apr 04 2015 7:57pm |
leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368 |
Hi mate, I'm in Tignes so a bit far for you but many thanks for the offer, what is an IID tool? |
Sat Apr 04 2015 8:12pm |
Yep, 400 miles.
Sat Apr 04 2015 8:16pm |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2794 |
Just an idea - try putting the passenger seat fully forward - disconnect & reconnect each connection at a time in the rear of the Sat Nav unit - never know it might reboot the system.
Sat Apr 04 2015 8:24pm |
Cheers, will give that a go in the morning |
Sat Apr 04 2015 8:56pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
You need to do a hard reset..
Sun Apr 05 2015 11:53am |
Update, it is now responding intermittently but more times not, Cheers Flack will try the hard reset, |
Mon Apr 06 2015 7:04am |
Further update, I think it does not like the cold, lefts all day in the sun yesterday and worked fine every time, parked up for an hour and temperature had dropped to freezing and not working, will get it a thermal jacket!!! |
Tue Apr 07 2015 7:24am |
Well hard reset carried out but still not working correctly, I'm lost on this one! |
Sun Apr 12 2015 5:18pm |
Sometimes some dirt can lodge inside the rim of the screen, this then stops it from responding to your touch, take the screen out and remove the screen bezel and check nothing is jammed in there, other than that you might need a new screen.
Mon Apr 13 2015 8:16am |
Hi Flack, many thanks for the advice, is there any instructions available on how to remove? |
Mon Apr 13 2015 10:54am |
Update, cleaned around the screen bezel, there was some dirt and some bits of grit in there, touch wood all working fine since, many thanks Flack |
Mon Apr 13 2015 7:17pm |
