Home > In Car Electronics > Urgent Help Please Sat Nav Screen Not responding to Touch
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Just arrived in the Alpes and out of the blue my sat nav screen is stuck on the agree page, when I touch the agree button nothing, not responding to touch, removed disc and cleaned but still will not allow me to confirm agree on warning screen, MY 2008, can anybody suggest the issue or resolution, do not fancy driving back to UK without sat nav.
Many thanks
Post #458234 Sat Apr 04 2015 7:52pm
myfirstrrs
Where are you roughly? I am in Gaschurn, Austria and I have an IID Tool with me if that can help.
Post #458236 Sat Apr 04 2015 7:57pm
leedsunited
Hi mate, I'm in Tignes so a bit far for you but many thanks for the offer, what is an IID tool?
Post #458240 Sat Apr 04 2015 8:12pm
myfirstrrs
Yep, 400 miles.
The IIDTool is a diagnostic tool for reading fault codes and changing some parameters on the car.
Good luck with getting home.
Post #458241 Sat Apr 04 2015 8:16pm
PEACHY
Just an idea - try putting the passenger seat fully forward - disconnect & reconnect each connection at a time in the rear of the Sat Nav unit - never know it might reboot the system.
Good luck Thumbs Up 16MY Estoril Blue SVR.............
Post #458243 Sat Apr 04 2015 8:24pm
leedsunited
Cheers, will give that a go in the morning
Post #458256 Sat Apr 04 2015 8:56pm
flack
You need to do a hard reset..
http://www.disco3.co.uk/wiki/Hard_Reset
Flack Thumbs Up
Post #458296 Sun Apr 05 2015 11:53am
leedsunited
Update, it is now responding intermittently but more times not, Cheers Flack will try the hard reset,
Post #458352 Mon Apr 06 2015 7:04am
leedsunited
Further update, I think it does not like the cold, lefts all day in the sun yesterday and worked fine every time, parked up for an hour and temperature had dropped to freezing and not working, will get it a thermal jacket!!!
Post #458454 Tue Apr 07 2015 7:24am
leedsunited
Well hard reset carried out but still not working correctly, I'm lost on this one!
Post #458963 Sun Apr 12 2015 5:18pm
flack
Sometimes some dirt can lodge inside the rim of the screen, this then stops it from responding to your touch, take the screen out and remove the screen bezel and check nothing is jammed in there, other than that you might need a new screen.
Flack Thumbs Up
Post #459007 Mon Apr 13 2015 8:16am
leedsunited
Hi Flack, many thanks for the advice, is there any instructions available on how to remove?
Post #459027 Mon Apr 13 2015 10:54am
leedsunited
Update, cleaned around the screen bezel, there was some dirt and some bits of grit in there, touch wood all working fine since, many thanks Flack Thumbs Up
Post #459076 Mon Apr 13 2015 7:17pm
