Home > Technical > LED Bulbs registering fault codes?
zaphod
I've recvently replaced most of my interior bulbs with LED's. 1 in the boot, the 3 front overhead lights, 4 doors, 2 under-dash and the 2 puddle lamps in the wing mirrors.
For some reason 2? of these are constantly generating faults that re-appear even when I clear them using my IID tool:
Body Control
B1D13-15 (2E) Interior lamps 1 circuit
B1D14-15 (2E) Interior lamps 2 circuit
All the LED's work but 2 of them must be dodgy in some way - does anybody know which lamps these faults refer to please?
Not a major problem (I hope) but annoying in an OCD sort of way! Wink
Post #458841 Sat Apr 11 2015 5:25pm
Disco_Mikey
As the LED's draw much less current, the car sees this as a fault.
Its nothing to worry about Thumbs Up
Post #458857 Sat Apr 11 2015 6:46pm
shakeapaw
I have also replaced mine, I made sure they where CANBUS ones, so the car does not see them as faulty, I would send them back and get some that work with the Canbus system 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #458871 Sat Apr 11 2015 8:52pm
zaphod
Thanks - I just assumed with them being Philips bulbs (not cheap) that they would be OK. Just had a look at their site and apparently I would need to buy a CANBUS warning canceller per bulb as well to get rid of the error which would double the cost of them... not to mention making them a pain in backside to fit.
Chucked all the packaging away now so can't really send them back. They're all working and unless I go looking for fault codes there is no apparent problem so will leave them be for now. At some point in the future I might upgrade my wifes car to LED's and sort the problem that way Wink
Post #458911 Sun Apr 12 2015 8:21am
shakeapaw
I got my led's from ebay, from a uk seller. i think they where £12 for 10 bulbs 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #458966 Sun Apr 12 2015 6:14pm
tone 123
England 2005 Range Rover Sport Supercharged Java Black
got mine from ebay £5 for 10 no problems.
Post #459761 Sun Apr 19 2015 2:31pm
zaphod
Mine were £13 for..... 2 bulbs! Embarassed
There are no problems really - no errors appear on the dash or anything like that. Just that when I do a check for fault codes there are some listed for interior lights... whether that would happen with your eBay ones too I don't know.
Basically if I didn't keep messing about with my IIDtool I'd be none the wiser and assume everything was fine Thumbs Up
Post #459850 Mon Apr 20 2015 11:36am
Lost for Words
I have several LED bulbs on mine that cost £25 a pair and my H8 cornering ones were over £20 each, but then, those are all exterior ones...
You just have to get used to ignoring some codes when you have a diagnostic tool. Thumbs Up Visiting from DISCO3.CO.UK
Post #459852 Mon Apr 20 2015 11:45am
zaphod
Sidelights are next on my list... was going to go with the Osram ones given they'll get heavy use...
Wasn't aware you could get some for the cornering lamps too though so they're on the list now too! Would like to replace the foglamp bulbs as well if that's possible?
Post #459855 Mon Apr 20 2015 12:01pm
Lost for Words
Mine are all HIDs4u:
Cornering lamps: http://www.hids4u.co.uk/h8-28-led-foglight...power.html There's an H11 version for the fogs but do consider that the beam pattern will be affected. I'm very happy with them as cornering lamps but don't have them in the fogs as I'm doing something else with them so can't comment on that.
Sidelights: http://www.hids4u.co.uk/501-led-bulb-long-...white.html 5000k matches the xenons nicely. The shorter, amber version is great for side indicator repeaters.
These look great in the D3 clusters as tail/brake bulbs - an intense red glow. Not paid any attention to the RRS clusters - Do they take bulbs or are they already LEDs? http://www.hids4u.co.uk/380-Ultimate-Canbus-92-SMD-LED-Bulb.html Amber 382 version for the indicators too (need resistors). Smile
15% off with DISCO315. Wink
Post #459859 Mon Apr 20 2015 12:28pm
zaphod
Thanks for the links, unfortunately 2 of the 3 are out of stock but I'll get those 501's for the sidelights for sure as mine look simply awful alongside the Xenons.
I've used HIDs4u before too so have no qualms about ordering stuff off them. I actually received a 10% code with my last order but your code trumps that so even better Thumbs Up
Post #459862 Mon Apr 20 2015 12:40pm
Lost for Words
Yeah, shame they're out of stock.
I should clarify, the 5000k ones match the OEM xenons. Those with higher kelvin bulbs will probably want to go for the 6000k ones. Wink Visiting from DISCO3.CO.UK
Post #459863 Mon Apr 20 2015 12:46pm
zaphod
Definitely reckon on 5000k to match Xenons then and not 6000K (gonna order some this afternoon) Very Happy
EDIT: OK - your last post has sowed the seeds of doubt lol - how do I know what bulbs I have?
Post #459864 Mon Apr 20 2015 12:47pm
Lost for Words
You can take the cover off the lights and take a look but otherwise, it's just how blue they are. Like this:
Many fit the 6000k+ ones as they like the blue tinge but it only reduces the light output (in the case of HIDs).
Post #459966 Tue Apr 21 2015 8:21am
zaphod
That's really helpful thanks. I'm not aware of any blue tint to my headlamps - the closest match in that picture would be the 4300k ones I think so 5000k would be the way to go... however they're out of stock too!!! Big Cry
Post #459972 Tue Apr 21 2015 8:45am
