Home > Maintenance & Modifications > 2011 Tdv6 rear pads need changing. |
if youre just changing the disk pads, then you don't need to touch the handbrake. Altough its as good a time as any to check them for wear and adjust accordingly. Bodsys Brake Bible
Mon Mar 16 2015 2:18pm |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 |
Belting
Mon Mar 16 2015 3:38pm |
Sorry should have read 'Bodsy' |
Mon Mar 16 2015 3:39pm |
The light has come on to say the pads need changing so obviously will need to change the sensors. Is there one on each side?
Mon Mar 23 2015 9:31pm |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
You only have 1 sensor on the drivers rear side and 1 on the front passenger side. Make sure you check the sensor first as I had this flag up and could see the pads had plenty of meat on them. Turned out to be a broken sensor cable. Changed cable and all OK. |
Mon Mar 23 2015 10:53pm |
Thank you for that ABSport |
Tue Mar 24 2015 12:12am |
JK07 Member Since: 27 Feb 2015 Location: Melbourne Posts: 9 |
I am doing the same. But changing all front and rear brake pads.
Tue Mar 24 2015 3:10am |
Changed the rear pads & sensor today with no problems.
Sun Mar 29 2015 9:25pm |
