Home > Maintenance & Modifications > 2011 Tdv6 rear pads need changing.
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I need to change the Rear Pads on our RRS TDV6. I have been told there maybe an issue regarding the Electronic Handbrake release. The handbrake pads are fine just the brakes themselves. I understand I can release the handbrake by keeping it pressed down for a no of seconds. Is that all I need to do so I can then change the normal brake pads?
Kind Regards
Frank
Post #456050 Mon Mar 16 2015 1:47pm
Bodsy
Site Sponsor
if youre just changing the disk pads, then you don't need to touch the handbrake. Altough its as good a time as any to check them for wear and adjust accordingly. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #456052 Mon Mar 16 2015 2:18pm
fdhadi
Belting
Thanks for that Bodsey
Post #456059 Mon Mar 16 2015 3:38pm
fdhadi
Sorry should have read 'Bodsy' Embarassed
Post #456060 Mon Mar 16 2015 3:39pm
fdhadi
The light has come on to say the pads need changing so obviously will need to change the sensors. Is there one on each side?
Thanks.
Frank
Post #456978 Mon Mar 23 2015 9:31pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
You only have 1 sensor on the drivers rear side and 1 on the front passenger side. Make sure you check the sensor first as I had this flag up and could see the pads had plenty of meat on them. Turned out to be a broken sensor cable. Changed cable and all OK. Thumbs Up
Post #456986 Mon Mar 23 2015 10:53pm
fdhadi
Thank you for that ABSport
Post #456988 Tue Mar 24 2015 12:12am
JK07
Australia 2012 Range Rover Sport 3.0 TDV6 SE Fuji White
I am doing the same. But changing all front and rear brake pads.
After a lot of research and past history I found Bendix Brake Pads are the best.
Bendix Rear Brake Pads Part Number BENDIX DB1781-4WD
http://www.ebay.com.au/itm/121351537823
Bendix Front Brake Pads Heavy Duty BENDIX DB2073-HD
http://www.ebay.com.au/itm/121311981348
Bendix Rear Brake Park Shoes BS5097
Post #456991 Tue Mar 24 2015 3:10am
fdhadi
Changed the rear pads & sensor today with no problems.
Thanks again for your help. Thumbs Up
Post #457568 Sun Mar 29 2015 9:25pm
