Home > Technical > Any advice on judder when accelerating? |
Hamner Member Since: 28 Jan 2015 Location: Swansea Posts: 54 |
Hi to all - I am new to the forum and wonder if any of you could help.
Wed Jan 28 2015 7:18pm |
hi thanks for reply would it be best to change the torque converter and give the gearbox flush a miss any idea cost to do this thanks for your help |
Wed Jan 28 2015 7:35pm |
ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27 |
The coat of a new torque converter from Vanmatic is about £450 inc vat. It's about 8 -10 hours labour to fit it. You'd fill the transmission with new oil at the same time. Total cost about £1000 |
Wed Jan 28 2015 8:02pm |
hey thanks for that i will take a look into it a bit deeper |
Wed Jan 28 2015 8:13pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Why not try a couple of tubes of this first?
Wed Jan 28 2015 8:24pm |
hey hi joe that looks good have you had the problem aswell and did it work how many tubes will it take and wear does it go ha ha cheers |
Wed Jan 28 2015 8:37pm |
No not had the problem however had a recent gearbox service and saw Disco Mikey and some other guys recomend to put this in as part of the gearbox service. I think they use it when they do a mega flush which I think is about £350.
Wed Jan 28 2015 8:43pm |
cheers for that joe the judder is not to bad and only happens now and then just trying to sort out a few snags how do you find the hst version thanks Hamner |
Wed Jan 28 2015 8:55pm |
If its only mild shudder a couple of tubes of that might help. A gearbox flush from Bodsy will deffinately help.
Wed Jan 28 2015 9:22pm |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
i have tried that in my gearbox and it did stop judder for a while but its not a permanent fix if gearbox has started to go wrong, do you have any warning lights like an f on dash |
Wed Jan 28 2015 10:35pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4396 |
If you have a judder, an additive will mask the issues, but it's time to start saving for a gearbox rebuild...
Wed Jan 28 2015 10:46pm |
Disco Mikey,
Wed Jan 28 2015 10:49pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
I would add, If you are not able to get it flushed, then you should at least change the gearbox oil a few times. e.g. Make the gearbox oil change part of your annual service In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Thu Jan 29 2015 9:32am |
Afraid I don't do gearbox flushes. Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
Thu Jan 29 2015 9:52am |
