Home > Technical > Any advice on judder when accelerating?
Hamner
Wales
hi bodsy thanks for the update there is a guy near me who does a mega flush so i might try that see if it helps but while your on i need to sort out my blackberry phone to stay on with out putting the code in every time can you help with that cheers Hamner
Post #450214 Thu Jan 29 2015 2:15pm
Bodsy
Site Sponsor
I can yes Thumbs Up
Will drop you a PM. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #450215 Thu Jan 29 2015 2:20pm
Hamner
Wales
hi interested got the pm can you give me a bit more info like does the module do all the stuff i,e gear reset and the three flashes ect and yes i need to put in the 2121 code and my phone works fine then hope this helps cheers hamner
Post #450259 Thu Jan 29 2015 5:55pm
