![]() | Home > General > Side strips on doors |
Maxarn58 Member Since: 24 Dec 2011 Location: Stockholm Posts: 142 ![]() ![]() ![]() |
Hello Calder.
Rubber or plastic strip? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Calder Member Since: 10 Jan 2015 Location: Derby Posts: 21 ![]() ![]() ![]() |
Sorry the one thin one half way down the door as per pic
In my gallery |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Hi
So I can remove with some heat and polish off the glue? |
Yes they are held on with double sided tape only. Warm with hot air gun/Mrs hair dryer and shouldn't leave much glue. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Many thanks for the info I will be removing them at the weekend
You could always have them colour coded. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
No I think they look better with out them so off they come tomoz |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
make sure any panels haven't been painted up to the rubber moulding as it could end up disastrous |
Good thinking I will check first
