Home > General > Side strips on doors
Calder
England 2006 Range Rover Sport TDV6 HSE Rimini Red
Hi can any one tell me if the side strip ( lower part of door ) on the doors can be removed ? Are they bolt on or glued on
Many thanks Confused
Post #449286 Wed Jan 21 2015 6:53pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
Hello Calder.
Du You mean the mouldings at the bottom of the door?
They are attached with clips.
Rgds
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #449308 Wed Jan 21 2015 8:59pm
simple1
Rubber or plastic strip? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #449309 Wed Jan 21 2015 9:02pm
Calder
Door strps
Sorry the one thin one half way down the door as per pic
Thanks
Post #449311 Wed Jan 21 2015 9:03pm
Calder
In my gallery
Post #449312 Wed Jan 21 2015 9:03pm
Hi
The are stuck on.
Post #449313 Wed Jan 21 2015 9:07pm
Calder
So I can remove with some heat and polish off the glue?
Post #449321 Wed Jan 21 2015 9:38pm
simple1
Yes they are held on with double sided tape only. Warm with hot air gun/Mrs hair dryer and shouldn't leave much glue. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #449439 Thu Jan 22 2015 11:17pm
Calder
Many thanks for the info I will be removing them at the weekend
Thanks
Post #449441 Thu Jan 22 2015 11:36pm
SRE
Spain
You could always have them colour coded. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #449463 Fri Jan 23 2015 10:53am
Calder
No I think they look better with out them so off they come tomoz
Post #449500 Fri Jan 23 2015 6:38pm
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
make sure any panels haven't been painted up to the rubber moulding as it could end up disastrous Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #449505 Fri Jan 23 2015 7:31pm
Calder
Good thinking I will check first
Many thanks
Post #449508 Fri Jan 23 2015 8:02pm
