Home > Maintenance & Modifications > Misfire on Start up
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Misfire on Start up
Hi Chaps
Just started occurring lately when I start the Sport which is 2006 TDV6.
The engine seems to have like a misfire on tickover, No problems when giving it a rev up,but back to the same on tickover again .seems to go away when car gets up to normal temperature though.
Any thoughts would be greatly appreciated.
Cheers Jock. Confused
Post #448500 Wed Jan 14 2015 10:10pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Hi Jock, I think these TDV6 engines are a lottle tempramental when the weather gets down to like 1 degree. I believe its something to do with injectors. Its not really a fault of such I just don't think they cope so well in cold weather.
This was a service bulletin from Land Rover in 2007 for the TDV6 Engine http://www.rrsport.co.uk/gallery/albums/us...0047v2.pdf I'm not Fat. RRS TDV6 HST.
Post #448502 Wed Jan 14 2015 10:14pm
Jock 77
Re Misfire
Thanks for the reply Joe
Just trying to make sure that its not something that could cause more damage down the line.
Cheers Jock. Smile
Post #448510 Wed Jan 14 2015 11:22pm
Bodsy
Site Sponsor
Get disco Mikey to have a look at the live value to fix it. Could be oil temp sensor. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #448513 Wed Jan 14 2015 11:32pm
Jock 77
Re Misfire
Hi Bodsy
Thanks for the reply mate.
Cheers Jock
Post #448515 Wed Jan 14 2015 11:39pm
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Mine does the same.
What I've started to do is turn the engine so the glow plugs light up and the dash light goes off (I do this 2 or 3 times) - not sure if this is warming them up and extra, sure someone will inform me, but the time the glow light stays on gets shorter.
Then, once the engine is running I just apply light revs to 1000 rpm for about 20-30 seconds. This seems to get rid of the lumpy idle, then I drive to work....
No idea if there's anything scientific in there, but it seems to work??? 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #448523 Thu Jan 15 2015 8:59am
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, my Disco 3 was also like this until I cleaned the MAF sensor on the top of the engine (ish) made a lot of difference to the running and especially the tick over Thumbs Up (think its called the MAF or could be the MAP sensor but i'm sure some one will correct me if wrong) Embarassed 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #448569 Thu Jan 15 2015 5:55pm
Jock 77
Re Misfire on Start-up
Thanks very much again lads for the suggestions. Will give them a try .Will locate the Maf /Map sensor and give it a clean.
Can you give any clues as to location and I take it that its only held in with a couple of small bolts.
Cheers again Jock Smile
Post #448577 Thu Jan 15 2015 7:54pm
Gornal Hills
Hi Jock, when you pull the engine cover off it's on top of the air intake with a plug attached, I think it's a torx screw if I remember .Removed mine and cleaned all the soot of it as it was filthy, also try to clean the small hole out but don't poke with a needle !! Im sure someone will upload a picture of this but I ain't got a clue how to sorry. Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #448932 Mon Jan 19 2015 12:18am
Jock 77
Re misfire on start-up
Cheers for that
I am off the next couple of days so I will try and get a look at this over these next two days. Always wary when these kind off things start happening in case it is leading to a major fault.
Cheers Jock. Smile
Post #448935 Mon Jan 19 2015 1:44am
Jock 77
Re misfire on start up
Hi lads
Cleaned the Map sensor yesterday and it seems to have made a bit of a difference although it hasn't cured it fully.
Also noticed that the plug was off the first sensor on the air inlet after the Air Filter box ,which is positioned at front drivers side..Not sure how this has happened or what this sensor is for. Now re-connected . Will run it for a bit and see how we get on.
Is it worth running a diesel cleaner additive through the system or is this not a good idea.
Post #449267 Wed Jan 21 2015 5:18pm
Lost for Words
To clarify, you're thinking of the MAP sensor (Manifold Absolute Pressure). Easy enough to clean but don't poke anything into the hole.
The sensor at the air filter box is the MAF meter (Mass Air Flow - measures the amount of air going into the engine). This is very easy to damage but some have had success using electrical contact cleaner. Best not to touch it unless you can guarantee it's the problem. Wink
Jock, when you say plug, I assume you mean the electrical connector? If this is disconnected you're bound to have problems. Thumbs Up
The best thing to run it on is two-stroke oil. 400ml per tank (500 is easier) is supposed to be the optimum amount. It must be JASO FB spec (FC is better or compulsory for DPF cars). Castrol Actevo is FC spec. You'll get more MPG too. Smile
Thumbs Up Visiting from DISCO3.CO.UK
Post #449277 Wed Jan 21 2015 5:54pm
Jock 77
Re misfire on Start up
Cleaned the Map sensor when removed with Intake and carb cleaner only, no poking.
Yeah sorry the electrical connector at the sensor just after the air filter box was disconnected ( not sure how long it has been like this ) ,just behind headlight / front grill on drivers side. Never had any alarms or warnings up .
Might be better running it for a bit to see if it gets better now that this sensor is hopefully working after re-connection.
Cheers again Jock. Confused
Post #449281 Wed Jan 21 2015 6:08pm
FatJoe
Hey Jock how was your motor after trying all this stuff? I'm not Fat. RRS TDV6 HST.
Post #451302 Wed Feb 04 2015 11:00pm
Jock 77
Re. Misfire on Start-up
Hi Joe
I have just run the car since my last post, The misfire has all but gone and can't believe the difference in performance but I am putting this down to the MAF sensor being disconnected. Its amazing how you just get used to the power you have and don't think there is anything wrong, reckon this sensor has been disconnected for some time.
Haven't run anything through with the fuel for cleaning and a bit wary to look into cleaning the MAF sensor after hearing how delicate it is . Have also noticed that I don't seem to be getting the same cloud when accelerating hard or kicking down.
Still hoping this sensor being disconnected hasn't done any long term damage ,Also due a service shortly so this might help the the tickover even more.
Cheers again for all the help Jock. Thumbs Up
Post #451321 Wed Feb 04 2015 11:36pm
