Home > Maintenance & Modifications > Misfire on Start up |
Jock 77 Member Since: 13 Apr 2012 Location: Falkirk Posts: 187 |
Hi Chaps
Wed Jan 14 2015 9:10pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Hi Jock, I think these TDV6 engines are a lottle tempramental when the weather gets down to like 1 degree. I believe its something to do with injectors. Its not really a fault of such I just don't think they cope so well in cold weather.
Wed Jan 14 2015 9:14pm |
Thanks for the reply Joe
Wed Jan 14 2015 10:22pm |
Get disco Mikey to have a look at the live value to fix it. Could be oil temp sensor. Bodsys Brake Bible
Wed Jan 14 2015 10:32pm |
Hi Bodsy
Wed Jan 14 2015 10:39pm |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Mine does the same.
Thu Jan 15 2015 7:59am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, my Disco 3 was also like this until I cleaned the MAF sensor on the top of the engine (ish) made a lot of difference to the running and especially the tick over (think its called the MAF or could be the MAP sensor but i'm sure some one will correct me if wrong) 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Thu Jan 15 2015 4:55pm |
Thanks very much again lads for the suggestions. Will give them a try .Will locate the Maf /Map sensor and give it a clean.
Thu Jan 15 2015 6:54pm |
Hi Jock, when you pull the engine cover off it's on top of the air intake with a plug attached, I think it's a torx screw if I remember .Removed mine and cleaned all the soot of it as it was filthy, also try to clean the small hole out but don't poke with a needle !! Im sure someone will upload a picture of this but I ain't got a clue how to sorry. 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Jan 18 2015 11:18pm |
Cheers for that
Mon Jan 19 2015 12:44am |
Hi lads
Wed Jan 21 2015 4:18pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
To clarify, you're thinking of the MAP sensor (Manifold Absolute Pressure). Easy enough to clean but don't poke anything into the hole. The sensor at the air filter box is the MAF meter (Mass Air Flow - measures the amount of air going into the engine). This is very easy to damage but some have had success using electrical contact cleaner. Best not to touch it unless you can guarantee it's the problem. Jock, when you say plug, I assume you mean the electrical connector? If this is disconnected you're bound to have problems. The best thing to run it on is two-stroke oil. 400ml per tank (500 is easier) is supposed to be the optimum amount. It must be JASO FB spec (FC is better or compulsory for DPF cars). Castrol Actevo is FC spec. You'll get more MPG too. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Wed Jan 21 2015 4:54pm |
Wed Jan 21 2015 5:08pm |
Hey Jock how was your motor after trying all this stuff? I'm not Fat. RRS TDV6 HST. |
Wed Feb 04 2015 10:00pm |
Hi Joe
Wed Feb 04 2015 10:36pm |
