Home > Maintenance & Modifications > EGR blanking |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4403 |
It is advisable to remove it, as when closed, there will be a huge depression in the intake system after the butterfly. This is less than ideal
Fri Jan 09 2015 12:39pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Can I ask, whilst Disco Mickey is around, what is the benefit of EGR blanking?
Fri Jan 09 2015 1:37pm |
You will only notice a difference in performance, if you have an EGR issue
Fri Jan 09 2015 5:59pm |
Thank you DM. Great advice as always.
Wed Jan 14 2015 9:24am |
Jemmountford Member Since: 04 Oct 2014 Location: Warwickshire Posts: 20 |
Right,
Mon Jan 19 2015 4:50pm |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Do you have any pics or a link to the instructions? I blanked off my egr valves a couple of years ago but didn't remove anything, am a bit concerned after reading what Mikey has said..... |
Mon Jan 19 2015 8:10pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Removed mine completely including the pipes that we're no longer needed. I'm not Fat. RRS TDV6 HST. |
Mon Jan 19 2015 8:31pm |
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 |
What if any are the downsides of blanking off the EGR?
Tue Jan 20 2015 12:35am |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 |
i removed everything on mine, egrs,pipes,cat,centra box insides,rear exhaust boxes and it goes well sounds great and better mpg |
Tue Jan 20 2015 7:21am |
I think they fit one because it helps reduce polution and gasses or something. But these build up, clog up and break and when they break are very costly. I'm not Fat. RRS TDV6 HST. |
Tue Jan 20 2015 7:33am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
As above, they're fitted to reduce SO2 and NOx emissions - In the process, feeding filth into your engine. On (later) DPF models, they are used to control the exhaust gas temperatures for the DPF regeneration cycle too. Blanking them will raise the EGTs a bit, BUT, when under load, they should be fully closed anyway. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Tue Jan 20 2015 9:32am |
Thanks for the replies folks, now it's clear why it's done. |
Tue Jan 20 2015 1:53pm |
Fritz Member Since: 24 Jan 2015 Location: NRW Remscheid Posts: 6 |
When I removed the EGR's I fitted a K&N air filter and a Hiclone Air Swirling device. The effect was very good. Have since added a Allisport Intercooler. Result better fuel consumption and Performance. |
Sat Jan 24 2015 5:06pm |
Fritz, just to let you know, such oiled filters can (and have been known to) cause damage to the MAF sensor. It's often said that the best thing is just to change the standard air filter more often.
Sun Jan 25 2015 9:27am |
