![]() | Home > General > Help looking for a replacement 2.7 TDV6 |
Nhlboy44 Member Since: 29 Nov 2014 Location: Essex Posts: 18 ![]() ![]() ![]() |
Hi Mikey Well here is another twist when my guy came over today the engine is turning over ??? He wasn't sure what to do now so is going to try speak to a friend who has worked on rr Any ideas ? |
Had the same with my own car. When the engine was hot, everything seized up. When it was cold, it would turn over fine, and given enough persuasion, it would run... |
And what was the problem? |
Oil filter fitted wrong, causing the oil flow through the engine to be affected, and piston started overheating and melting... |
Ok
hi Mikey
ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27 ![]() ![]() ![]() |
Did you dismantle your engine to see what the fault was? |
Not yet but my mechanic took sump off
Sounds familiar...
