Home > General > Help looking for a replacement 2.7 TDV6 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4418 |
Eurojag |
Sun Dec 28 2014 11:00am |
Nhlboy44 Member Since: 29 Nov 2014 Location: Essex Posts: 18 |
Thanks Mikey for the response
Sun Dec 28 2014 11:26am |
Go with the eurojag ones as Mikey said.
Sun Dec 28 2014 1:43pm |
I paid £2500 for a 49k engine. They did have cheaper ones available, but with a higher mileage.
Sun Dec 28 2014 3:28pm |
not sure yet as my mechanic will come over tomorrow to strip it down.I had a new belt and tension fitted only 600 miles ago but there was a low tone noise coming from engine and Lookers land rover suspected timing chain or valves but they were not 100%. It would of cost me at least £1300 min for them to fault find and then that could of risen as they were not going to gaurentee it would end there.Plus that was only to strip to middle engine if more extensive striping the meter was running as they say. So i could of had a bill of over £2K and then still not fixed the problem so i thought would take my chances as i knew rough price for recon or second hand engine would be around £2500. Once i know what the reason for failure was ill post the result. The car has only done 68000 miles from new and its an 08 with full history and only 2 owners. |
Sun Dec 28 2014 6:18pm |
Thanks Mikey once my guy has had a look ill post the result.I will give Eurojag a call in the morning thanks again for your advice |
Sun Dec 28 2014 6:21pm |
If it is the oil pump, it will take around 45 mins to strip and check. Failing that, I have seen a few 08s with broken con rods and crankshafts
Sun Dec 28 2014 6:27pm |
Thanks Mikey i will advise him tomorrow
Sun Dec 28 2014 6:31pm |
Copy of the SSM:
Some members of the D3 forum have had engines replaced fully FOC. If you don't ask... |
Sun Dec 28 2014 6:44pm |
Michael7s Member Since: 26 Oct 2014 Location: London Posts: 38 |
I'm wondering why LR dealers don't sell engine parts (piston rings etc) to fix the engine.
Sun Dec 28 2014 11:36pm |
If you have full service history, then this type of issues should be pushed back to LR to resolve. Especially at the mileage you have. Did LR do the timing belt?
Sun Dec 28 2014 11:47pm |
Hi There
Mon Dec 29 2014 7:38pm |
I agree if it is a problem why don't they sell replacement part like all other manufacturers ?? |
Mon Dec 29 2014 7:41pm |
Bodsy is your man. He has been there and done that. A PM to him would be well worthwhile |
Mon Dec 29 2014 7:59pm |
