Home > Technical > Passenger side rear brake light not working |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Try another bulb in its place first. Very common for brake bulbs to fail |
Wed Dec 31 2014 7:51pm |
seankenyon Member Since: 21 Jul 2014 Location: Warrington, Cheshire Posts: 35 |
Cheers Mikey ill give that a try and report back, I'll use the brake bulb from the opposite side as a test, I swapped it for an old Discovery bog standard bulb which didn't work, went for the easy option
Wed Dec 31 2014 8:38pm |
Swapped the brake bulbs around and the passenger side still doesn't work
Fri Jan 02 2015 12:31pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Can you swap the clusters side for side to see if the problem is up range or down range? |
Fri Jan 02 2015 12:37pm |
Yeah I can give that a try and will report back, cheers |
Fri Jan 02 2015 12:47pm |
Had some work done recently on the same side, seized rear calliper, is that just a coincidence? |
Fri Jan 02 2015 12:49pm |
Bought brand new replacement bulbs, swapped out both sides and made no difference, any ideas where the fault is? |
Mon Jan 05 2015 11:02pm |
Hate to admit it but I was changing the wrong bulb this is what happens when you try to check the brake lights on your own and its the first time ive removed the tail light covers on this type of car.
Mon Jan 12 2015 11:12am |
Sorted by sanding the connections on the new bulbs to ensure a better fitment |
Tue Jul 28 2015 5:30pm |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
I think you'll find that you had fitted bulb the wrong way round which is why it was difficult to fit, also explained the dim brake light, no doubt you had a very bright side light 2008 G4 RRSport TDV8 current
Tue Jul 28 2015 9:51pm |
