Home > Technical > Passenger side rear brake light not working
seankenyon
United Kingdom 2005 Range Rover Sport TDV6 HSE Arctic Frost
I've checked the bulb and the fuse and all is ok, the other brake lights work fine, checked the connections and wiring revealed by removing the light cluster but no obvious signs of damage or deterioration Big Cry
Any suggestions Question
Cheers guys Thumbs Up
Post #446939 Wed Dec 31 2014 7:25pm
Disco_Mikey
Try another bulb in its place first. Very common for brake bulbs to fail Thumbs Up
Post #446943 Wed Dec 31 2014 7:51pm
seankenyon
Cheers Mikey ill give that a try and report back, I'll use the brake bulb from the opposite side as a test, I swapped it for an old Discovery bog standard bulb which didn't work, went for the easy option Embarassed
Will update for the future of anyone else with the same issue
Post #446946 Wed Dec 31 2014 8:38pm
seankenyon
Swapped the brake bulbs around and the passenger side still doesn't work Mad
Gutted Big Cry
Post #447139 Fri Jan 02 2015 12:31pm
MAW
Can you swap the clusters side for side to see if the problem is up range or down range?
Post #447141 Fri Jan 02 2015 12:37pm
seankenyon
Yeah I can give that a try and will report back, cheers Thumbs Up
Post #447142 Fri Jan 02 2015 12:47pm
seankenyon
Had some work done recently on the same side, seized rear calliper, is that just a coincidence?
Post #447143 Fri Jan 02 2015 12:49pm
seankenyon
Bought brand new replacement bulbs, swapped out both sides and made no difference, any ideas where the fault is?
Post #447519 Mon Jan 05 2015 11:02pm
seankenyon
Hate to admit it but I was changing the wrong bulb Embarassed this is what happens when you try to check the brake lights on your own and its the first time ive removed the tail light covers on this type of car.
Anyway, its still a head scratcher - I replaced both bulbs, the drivers side was a pain in the backside to turn into its locking position, it did eventually click into place but doesn't seem as bright as the passenger side Question
Even though I bought the more expensive GE bulbs I think the 2x metal connection points need sanding back a bit to enable a better connection and smoother locking motion, has anyone experienced this before Question
Cheers, Sean
Post #448224 Mon Jan 12 2015 11:12am
seankenyon
Sorted by sanding the connections on the new bulbs to ensure a better fitment
Post #468852 Tue Jul 28 2015 5:30pm
Camelrock
I think you'll find that you had fitted bulb the wrong way round which is why it was difficult to fit, also explained the dim brake light, no doubt you had a very bright side light Thumbs Up 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #468878 Tue Jul 28 2015 9:51pm
