Home > Technical > 2005 2.7 TDV6 wont start
chi
Hi All
Drove fine last night. Took to local shops and back at 5pm , all fine. This morning wont start .
Fairly cold here last night - 3/4 c. Heater plug symbol on dash lights and goes off after a few seconds but engine wont start. Engine turning over well and 1/2 tank of fuel.
Any idea,s ?
Thanks
Keith
CHI
Post #446778 Tue Dec 30 2014 4:24pm
Disco_Mikey
Check for fuel at the bleed point at the back of the engine bay. If there is a good flow if fuel there, it could be glow plug related
Post #446780 Tue Dec 30 2014 4:28pm
chi
Thanks Disco_mikey.
Where abouts at the rear of the engine bay is the bleed point?
Thanks
Keith
CHI
Post #446791 Tue Dec 30 2014 5:32pm
Disco_Mikey
Right in the middle of the "V", just behind the rear of the engine cover. Should have a grey plastic screw on cap
Post #446802 Tue Dec 30 2014 6:36pm
chi
Cheers Disco_Mikey
Post #446804 Tue Dec 30 2014 6:40pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
same here
mine didn't want to start this morning either just cranked and cranked but was kicking out smoke while cranking , put a jump pack on it and it started ?
Post #446821 Tue Dec 30 2014 8:31pm
Disco_Mikey
Signs of a weak battery, or non-functioning glow plugs...
Post #446822 Tue Dec 30 2014 8:33pm
Disco_Mikey
Fuel bleed point:
Post #446824 Tue Dec 30 2014 8:43pm
hard2beat2014
do i need a new battery
-2 this morning covered in frost tdv6 didn't want to start just cranking and diesel smoke from exhaust , checked battery only showing 11.5 volts , is this my problem
Post #447379 Sun Jan 04 2015 2:29pm
Disco_Mikey
Low voltage definitely won't be helping. It spins over much slower with a discharged battery, and so doesn't build as much temperature inside the cylinders for combustion Thumbs Up
Post #447412 Sun Jan 04 2015 7:37pm
