Home > Technical > 2005 2.7 TDV6 wont start |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Check for fuel at the bleed point at the back of the engine bay. If there is a good flow if fuel there, it could be glow plug related |
Tue Dec 30 2014 4:28pm |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 |
Thanks Disco_mikey.
Tue Dec 30 2014 5:32pm |
Right in the middle of the "V", just behind the rear of the engine cover. Should have a grey plastic screw on cap |
Tue Dec 30 2014 6:36pm |
Cheers Disco_Mikey |
Tue Dec 30 2014 6:40pm |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 |
mine didn't want to start this morning either just cranked and cranked but was kicking out smoke while cranking , put a jump pack on it and it started ? |
Tue Dec 30 2014 8:31pm |
Signs of a weak battery, or non-functioning glow plugs... |
Tue Dec 30 2014 8:33pm |
Fuel bleed point:
Tue Dec 30 2014 8:43pm |
-2 this morning covered in frost tdv6 didn't want to start just cranking and diesel smoke from exhaust , checked battery only showing 11.5 volts , is this my problem |
Sun Jan 04 2015 2:29pm |
Low voltage definitely won't be helping. It spins over much slower with a discharged battery, and so doesn't build as much temperature inside the cylinders for combustion |
Sun Jan 04 2015 7:37pm |
