![]() | Home > Technical > 2005 2.7 TDV6 wont start |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4459 ![]() ![]() ![]() |
Check for fuel at the bleed point at the back of the engine bay. If there is a good flow if fuel there, it could be glow plug related |
chi Member Since: 15 May 2010 Location: hampshire Posts: 49 ![]() ![]() |
Thanks Disco_mikey.
Right in the middle of the "V", just behind the rear of the engine cover. Should have a grey plastic screw on cap |
Cheers Disco_Mikey |
hard2beat2014 Member Since: 14 Jun 2014 Location: cambridge Posts: 63 ![]() ![]() ![]() |
mine didn't want to start this morning either just cranked and cranked but was kicking out smoke while cranking , put a jump pack on it and it started ? |
Signs of a weak battery, or non-functioning glow plugs... |
Fuel bleed point:
-2 this morning covered in frost tdv6 didn't want to start just cranking and diesel smoke from exhaust , checked battery only showing 11.5 volts , is this my problem |
Low voltage definitely won't be helping. It spins over much slower with a discharged battery, and so doesn't build as much temperature inside the cylinders for combustion |
