Home > General > Frozen Electric Mirrors = Stopped Working!
darrenmcneill
England 2006 Range Rover Sport TDV6 HSE Tonga Green
Evening!
Drivers side mirror has stopped folding in after some extreme frost/cold. I pressed to fold the mirrors in after a long journey, expecting them not to be frozen... but they were. Motors whirred away and they didnt go back in... Censored I thought.
Anyway, warmer today (at least 1oC) so tried when I got home from work. Passenger side folds in, Drivers doesnt. The motor is still working as I can hear it, but its not "gripping" the mirror.
Anyone advise me on how to resolve this issue? Had a search but no-one seems to have posted about this one.
Cheers! 2006 HSE for Sale - £7,499 (Manchester)
http://www.rrsport.co.uk/forum/topic46383.html
Post #446694 Mon Dec 29 2014 6:48pm
simple1
Try operating mirrors with gentle hand help at same time. It is only a small plastic cog so hopefully hasn't stripped teeth. Big Cry
I have a spare n/s but unfortunately not an o/s. Rolling Eyes 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #446748 Tue Dec 30 2014 11:34am
darrenmcneill
Yeah, tried that. You can feel that its trying to grip, but doesn't, so I'm presuming the teeth have worn.
Dont suppose anyone knows the item code for said part.... And how I go about stripping the mirror? 2006 HSE for Sale - £7,499 (Manchester)
Post #446758 Tue Dec 30 2014 2:31pm
simple1
You can get go the screws behind the tweeter, I can't remember if you need to take door panel off to get to the electrical plug but I'm sure one of our grown ups will be along shortly to remind us. Have no idea what the part number is but there are bound to be on eBay. Disco and Sport mirrors are the same 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #446759 Tue Dec 30 2014 2:35pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
It is easier to remove the door panel as you will not be able to remove the tweeter speaker assembly With out breaking the plastic lugs.it is only held on with 2 plastic lugs and 2 very thin plastic legs which are housed behind the door card. To remove the screws you will be better to remove the door card. Once this has been done you can remove the mirror. The mirror can actually be stripped down easily once you remove the mirror housing cover ( outer colour coded part ) you will see the electric motor wiring etc. Thumbs Up
Post #446762 Tue Dec 30 2014 3:18pm
darrenmcneill
Cheers,
Job for my week off next week. 2006 HSE for Sale - £7,499 (Manchester)
Post #446796 Tue Dec 30 2014 6:13pm
peanutbob
2008 Range Rover Sport TDV8 HSE Zermatt Silver
You could try squirting WD40 in the general direction of the mechanism before stripping it down. Worked for me when I had a Disco 4 with one mirror not opening.
Post #446813 Tue Dec 30 2014 7:36pm
darrenmcneill
Mirrors miraculously started working!!!
Result! Thumbs Up 2006 HSE for Sale - £7,499 (Manchester)
Post #447857 Thu Jan 08 2015 7:40pm
peanutbob
It's because it's milder...the slight lubrication will be more fluidic.
Post #447869 Thu Jan 08 2015 8:39pm
dazzerboy
England 2013 Range Rover Sport SDV6 Autobiography Bonatti Grey
neither of mine fold in should they do its a 55 plate hse did they have them fitted or was it an extra option ?
if it should have them what should i check apart from the fuse Thumbs Up
Post #447882 Thu Jan 08 2015 11:03pm
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
If it's a 55 plate it will have to be done manually via pressing the mirror adjuster down when it's set in the middle position.
Newer models close on locking. RRS HSE with a few extras & a
2013 RRS Autobiography
Post #447886 Thu Jan 08 2015 11:30pm
dazzerboy
thanks uk guy but it doesn't work pushing it down that's why I was wondering if it had electric fold in mirrors ? if so they must be broke
Post #447888 Thu Jan 08 2015 11:36pm
UK Guy
Mmmm.... If it's a HSE it should have. It may be a fuse blown.
Best way to tell is try pushing them in manually. Do they manually move easily? RRS HSE with a few extras & a
Post #447977 Fri Jan 09 2015 6:52pm
dazzerboy
yes they push in easily what fuse would I look for ?
Post #447980 Fri Jan 09 2015 7:04pm
UK Guy
Not sure.... Maybe someone with a manual can advise RRS HSE with a few extras & a
Post #448108 Sun Jan 11 2015 11:02am
