Home > Technical > Battery Reccomendations and what to look out for |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Exide Premium |
Mon Dec 29 2014 10:42am |
http://www.tayna.co.uk/EA1000-Exide-Premiu...P7488.html
Mon Dec 29 2014 10:44am |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
i used Tanya for my last car battery and their service was great
Mon Dec 29 2014 11:00am |
Its only £3.50 off |
Mon Dec 29 2014 11:03am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Hi I upgraded to a Varta Silver Dynamic H3 100amp for my 3.0 HSE. Bought it from EUROBATT £82.44 including next day delivery. 5 Years Warranty itisme |
Mon Dec 29 2014 11:33am |
The Varta is a 100Ah, 830CCA battery
Mon Dec 29 2014 11:44am |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
The genuine LR battery is an AGM battery part number is LR033179. (mine is made by exide) Not sure what age your Sport is, however JLR have been fitting AGM batteries now for several years, so your existing battery could well be an AGM battery.
Mon Dec 29 2014 1:25pm |
AGM were standard fit in 2010>on MY's, and essential for those models with stop/start
Mon Dec 29 2014 1:29pm |
V8SC Member Since: 29 Oct 2011 Location: Hampshire Posts: 145 |
+1 for the Exide Premuim 900cca - Just got one for my 55 plate S/C. Immediately got rid of the "HDC is not available" occasional message on cold starts Carl |
Mon Dec 29 2014 3:03pm |
R12345a Member Since: 05 Apr 2014 Location: Manchester Posts: 22 |
Thanks guys. Ive ordered an Exide Battery as recommended by Disco_Mikey. Hopefully it will be simple to remove and fit for a simple man like myself. The current battery does not seem to be connected to the vent tube. Can anyone shed any light? |
Mon Dec 29 2014 10:48pm |
That's a pint of lager |
Tue Dec 30 2014 8:14am |
Undo both terminals with a 13mm Undo clamp bolts, both 8mm Lift battery. Its heavy Replace battery in tray Connect up terminals. They should go right down. If not, ease the clamp open with a screwdriver Tighten terminals and refit clamp There is a hole for the vent pipe, so if it hasnt been crushed or squashed, fit it in the hole Job done |
Tue Dec 30 2014 8:59am |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 |
Slightly familiar. Land Rover - Turning Drivers into Mechanics Since 1948 How To - Battery & Quiescent Current Drain Testing Free Fault Code Reading For Established Members: Defender, FL2, D3, D4, Evoque, RRS & FFRR |
Tue Dec 30 2014 10:38am |
Sorry Robbo
Tue Dec 30 2014 10:52am |
