Home > Technical > Battery Reccomendations and what to look out for
R12345a
United Kingdom 2005 Range Rover Sport TDV6 SE Zermatt Silver
The time has come to change the battery on my 2.7 sport. Does anyone have any Reccomendations as to what I should buy or look out for?
Post #446640 Mon Dec 29 2014 9:47am
Disco_Mikey
Exide Premium Thumbs Up
Post #446644 Mon Dec 29 2014 10:42am
Disco_Mikey
http://www.tayna.co.uk/EA1000-Exide-Premiu...P7488.html
With the D2BOYS 5% discount code it is only £76 delivered.
Post #446645 Mon Dec 29 2014 10:44am
i used Tanya for my last car battery and their service was great Thumbs Up
wish i had the discount code too Big Cry
Post #446648 Mon Dec 29 2014 11:00am
Disco_Mikey
Its only £3.50 off Whistle Laughing
Post #446649 Mon Dec 29 2014 11:03am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: Battery Reccomendations and what to look out for
Hi I upgraded to a Varta Silver Dynamic H3 100amp for my 3.0 HSE. Bought it from EUROBATT £82.44 including next day delivery. 5 Years Warranty itisme
Post #446650 Mon Dec 29 2014 11:33am
Disco_Mikey
The Varta is a 100Ah, 830CCA battery
The Exide is a 100Ah, 900CCA battery, as well as being £15 cheaper
Post #446651 Mon Dec 29 2014 11:44am
SRE
Spain
The genuine LR battery is an AGM battery part number is LR033179. (mine is made by exide) Not sure what age your Sport is, however JLR have been fitting AGM batteries now for several years, so your existing battery could well be an AGM battery.
 In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #446659 Mon Dec 29 2014 1:25pm
Disco_Mikey
AGM were standard fit in 2010>on MY's, and essential for those models with stop/start
Unnecessary expense for an earlier car Thumbs Up
Post #446662 Mon Dec 29 2014 1:29pm
V8SC
2006 Range Rover Sport Supercharged Bonatti Grey
+1 for the Exide Premuim 900cca - Just got one for my 55 plate S/C. Immediately got rid of the "HDC is not available" occasional message on cold starts Thumbs Up Carl
Post #446668 Mon Dec 29 2014 3:03pm
R12345a
Thanks guys. Ive ordered an Exide Battery as recommended by Disco_Mikey. Hopefully it will be simple to remove and fit for a simple man like myself. The current battery does not seem to be connected to the vent tube. Can anyone shed any light?
Post #446713 Mon Dec 29 2014 10:48pm
That's a pint of lager Very Happy
Post #446725 Tue Dec 30 2014 8:14am
Disco_Mikey
Undo both terminals with a 13mm
Undo clamp bolts, both 8mm
Lift battery. Its heavy
Replace battery in tray
Connect up terminals. They should go right down. If not, ease the clamp open with a screwdriver
Tighten terminals and refit clamp
There is a hole for the vent pipe, so if it hasnt been crushed or squashed, fit it in the hole
Job done Thumbs Up
Post #446726 Tue Dec 30 2014 8:59am
Robbie
Location: Waiting for my old avatar to be allowed back... we miss her!
Slightly familiar.
Laughing Land Rover - Turning Drivers into Mechanics Since 1948
How To - Battery & Quiescent Current Drain Testing
Free Fault Code Reading For Established Members:
Defender, FL2, D3, D4, Evoque, RRS & FFRR
Post #446742 Tue Dec 30 2014 10:38am
SRE
Spain
Sorry Robbo
This IS mine
Post #446746 Tue Dec 30 2014 10:52am
