![]() | Home > Technical > Brake Pad Warning Light |
It's the same warning light for front and rear, so check the rears, it's also worth checking your fluid level. 2008 G4 RRSport TDV8 current
Simon58 Member Since: 01 Jun 2012 Location: Wiltshire Posts: 89 ![]() ![]() ![]() |
Thanks Camelrock will have a look if I can sneak out today |
so had a look at the rear pads today they are like new, so now a little stumped to why the 'check brake pads' alert comes on now and again, does that mean because the front pads warning touched you have to change the sensor wire too! About to get into a sport |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4455 ![]() ![]() ![]() |
If the sensor has worn down until the light has come on, it will need replaced.
thanks DM will change it About to get into a sport |
change and all good as always thanks for the advice DM About to get into a sport |
CRACKA Member Since: 16 Sep 2014 Location: Hallam Victoria 3803 Posts: 170 ![]() ![]() ![]() |
Hi, just bringing back this thread.
The connection must be broken, so you need a new sensor, or you can chop it and short the wires as a temporary measure to put the light out. |
Thanks Lost for Words.
No, it works the other way round. The circuit is normally closed and, when the sensor wears through, it's broken. |
Okay,
Just to let everyone know I put in new rear pads today. It was the sensor wire that was broken.
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5039 ![]() ![]() ![]() |
Only one sensor at the front too. Opposite corner. |
