Home > Wheels & Tyres > RRS and third craked alloy
Page 1 of 3 123>
wilburn
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Nara Bronze
We have had our RRS for 3 years and had 3 cracked allows so far (latest one was yesterday which is currently being welded)
I am sick of this situation 😡 we don't drive fast, we look out for potholes but it simply isn't possible to avoid them all, especially when it's raining / poor visibility.
I'm looking to either change all 4 of the stupid 20 inch 275 wide and 40 profile wheels for something more sensible for road use or get rid of the vehicle and buy something that actually works on the roads.
Has anyone on here changed the standard alloys for smaller ones/less wide/higher profile/more sturdy
Thanks
Paul
Post #446103 Mon Dec 22 2014 3:55pm
Never had a cracked alloy myself, why not lodge a claim with your local council? You will need all the details of the offending pothole though.
Post #446104 Mon Dec 22 2014 4:00pm
SRE
Spain
Not sure, however I think some people have fitted a 20inch tyre with a 45 aspect ratio. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #446106 Mon Dec 22 2014 4:03pm
SRE
Spain
I have an alloy with a small flat spot in the inside, 100% my fault for running over speed bump a tad rapid Whistle this did not crack the wheel though. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #446108 Mon Dec 22 2014 4:05pm
wilburn
No point. Range Rover sport not fit for purpose.
This is the 3rd time 😥
I have an AC Cobra replica with 18 inch wheels at 35 profile and 285 wide. No issues and also a trusty 18 year old Audi A4 with steel wheels and high profile (16" inch?) wheels. No issues.
Range Rover sport wheels are too wide, too low profile and too much weight on them.
RRS = ReallyRatherShit
Post #446110 Mon Dec 22 2014 4:28pm
Sag
Will are your 20' wheels genuine? LCFC. Receiver of threatening letters from Overfinch.
Post #446111 Mon Dec 22 2014 4:29pm
B9BS X
sounds like youve had some bad luck mate.
ive got 22inch wheels on mines and have had other cars with 22's for years with no problems and there are lots of bad pot holes near were I live, unfortunatly unavoidable pot holes Big Cry RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #446114 Mon Dec 22 2014 4:36pm
wilburn
I believe so. Car was bought from Shuckers Land Rover in Shrewsbury, was 2 years old when we got it.
Post #446119 Mon Dec 22 2014 4:50pm
B9BS X
how much do u pay to get them repaired? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #446120 Mon Dec 22 2014 4:57pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Fit a set of standard 19" Alloys, you will get the best ride and won't suffer with anymore damage.. Thumbs Up
Post #446121 Mon Dec 22 2014 5:00pm
Somerset Bumpkin
2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Does it keep happening on the same corner or is it a different wheel from the original set that's broken each time? Could of been a bad batch from the factory. Something's definatly amiss, it's not common.
I have 45 profile tyres on my 20s because I hate the standard ride and the fact they're curb hunters, but I also use std 19" wheels with my winter rubber which is even better.
Post #446123 Mon Dec 22 2014 5:04pm
Disco
Re: RRS and third craked alloy
Thanks
Paul
Our 2014 has 22s with 275. No problems yet and we probably drive some of the same roads.
Beth's RS Focus has 19s with 245/35 and no issues yet.
Must be down to luck or lack of.
Have you had issues on the same bit of road??
Graham.
Post #446124 Mon Dec 22 2014 5:08pm
wilburn
Most places are around £60 + vat one place was £30 + vat
Unfortunately, we have never had a repaired one re-crack a new crack has always been on one that was never welded before.
Perhaps I should get a ring of welding all round on the inside where it flexes due to wheels being too wide?
Post #446130 Mon Dec 22 2014 5:57pm
wilburn
Original crack was front left, then back left and yesterday back right.
I am now thinking of getting the original range rover sport!
I mean a Discovery! Proper wheels and bit more room inside.
We were thinking of getting a new motor next year so toying with the idea of spending £xxx? on new wheels/tyres on this RRS or cutting our losses and getting a new motor.
I really do think I Discovery 4 ticks all the boxes for us.
Post #446131 Mon Dec 22 2014 6:00pm
What tyres do you have on it? Are they correctly rated for the vehicle? Be worth checking that the alloys are the correct ones too. Wouldn't be the first time a dealer has sold a RRS with incorrectly rated footwear... 2012 SDV6 - it's missing a couple of cylinders
Post #446150 Mon Dec 22 2014 7:51pm
Page 1 of 3 123>
