Home > Maintenance & Modifications > service advice needed |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
It's 15000 miles and one year which ever comes first. You history looks like mine. 3-4000 miles between services although exactly 12 months apart. You are a half service short, seems to be 18 months between two. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Dec 16 2014 7:05pm |
jenko2005 Member Since: 29 Jul 2014 Location: Rhoose Posts: 142 |
Strastone's full service 105k miles plugs, supercharger belt,aux belt, brake fliud, coolant all in for £590 including vat |
Fri Dec 19 2014 5:42pm |
That sounds like good value when I was charged £408 for a 60,000 service on a TDV8 which only has filters and oils. Mind you the oil alone was over £100. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Dec 19 2014 5:51pm |
Don't know the dealership; but if they are like all the others then once they have your car you will receive a 'phone call to tell you they have found all sorts of other expensive things that 'need doing sir'. Then your kecks come down.
Fri Dec 19 2014 6:51pm |
they can try to pull them down but wont get know where |
Fri Dec 19 2014 9:14pm |
Stuart Member Since: 17 Oct 2013 Location: Manchester Posts: 581 |
No reason to take an 06 car to a main dealer. Why pay daft money when it will add £0 value?
Sat Dec 20 2014 1:53am |
R12345a Member Since: 05 Apr 2014 Location: Manchester Posts: 22 |
Stuart - I notice you're also in Manchester. Do you have any recommendations in terms of indys which you have had a good experience with? |
Sat Dec 20 2014 7:55pm |
Land Ranger. Off Lancashire Hill in Stockport. Can be a bit of a wait to get in, but they are OK. Also "Flack" here, is a mobile bloke from nearbyish, Preston or somewhere. He knows his eggs too and is a good guy who wont nail your hat on. |
Sun Dec 21 2014 1:04am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
Get in touch with Flack. You won't be disappointed |
Sun Dec 21 2014 6:58am |
Stuart the indy was £100 more expensive plus they wanted an additional £45 for brake fluid change and £40 plus the dreaded vat for coolant in this instant the main dealer come in cheaper |
Sun Dec 21 2014 12:34pm |
Make sure you are comparing like-for-like servicing.
Sun Dec 21 2014 2:10pm |
service went well no problems changed everything as agreed car feels much better |
Wed Dec 31 2014 2:00pm |
