Home > General > FBH Activation help ?? |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Hi, due to the cold weather recently I thought my fbh may of fired up but afraid not, what's the basics for helping it along, cheers |
Mon Dec 08 2014 8:03pm |
Thanks for the reply, is this done by disconnecting a certain plug or wire ?? or at least worth a try 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Mon Dec 08 2014 9:35pm |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 |
I think there is mention of restarting the FBH in this thread mate....
Mon Dec 08 2014 9:56pm |
You know where I am if you need me. Bodsys Brake Bible
Tue Dec 09 2014 7:25am |
Cheers Bodsy, i'll give it a go but if no joy i'll be req your assistance 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Tue Dec 09 2014 8:02am |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
It will not opperate if the fuel is low or if battery is low on voltage. It will not use battery power that will be needed to start car,and will not use fuel that may be needed to get you to a garage. If these two things are not the reason. See if you can hear it working,from under bonnet N/S in front of Battery and Fuse box. It should work on its own every time you start engine,when temperature is below 15deg itisme |
Tue Dec 09 2014 8:54am |
Hi all, just to say it fired up yesterday with no smoke at all lovely warm cabin after a couple of miles. 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Thu Dec 11 2014 8:42am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Still get Bodsy round then you can have a nice warm cabin when you get in best thing about FullFat is that it comes with remote and also timer facility all of which can be added to a Sport I believe. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Dec 11 2014 10:52pm |
Yes and all for a Suppliment of £!025, when ordered from new. But Main agents say it cant be done after market. Yet i had mine done By Indie for Activation of software £50. And i fitted the rest for around £180. Well worth £230,Not £1025 to have a nice warm car in the morning itisme |
Fri Dec 12 2014 8:25am |
