Home > General > FBH Activation help ??
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, due to the cold weather recently I thought my fbh may of fired up but afraid not, what's the basics for helping it along, cheers Thumbs Up
Post #444709 Mon Dec 08 2014 9:03pm
It will need to be reset if it has locked out. One can supposedly do this without a code reader/clearer but it doesn't often work.
The FBH locks out for reasons such as low battery voltage, low fuel. 2012 SDV6 - it's missing a couple of cylinders
Post #444721 Mon Dec 08 2014 9:56pm
Gornal Hills
Thanks for the reply, is this done by disconnecting a certain plug or wire ?? or at least worth a try Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #444729 Mon Dec 08 2014 10:35pm
mad-dafty
Scotland 2010 Range Rover Sport 3.0 TDV6 Autobiography Stornoway Grey
I think there is mention of restarting the FBH in this thread mate.... Thumbs Up
http://www.rrsport.co.uk/forum/topic29610.html?highlight=fbh+wire 2010 RRS TDV6 3.0 Autobiography - Stornoway Grey
2006 RRS TDV6 2.7 HSE -Java Black
2008 BMW 3 Series 2.l
2006 BMW 5 series 2.l
Post #444732 Mon Dec 08 2014 10:56pm
Bodsy
Site Sponsor
You know where I am if you need me. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #444744 Tue Dec 09 2014 8:25am
Gornal Hills
Cheers Bodsy, i'll give it a go but if no joy i'll be req your assistance Bow down 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #444745 Tue Dec 09 2014 9:02am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Re: FBH Activation help ??
It will not opperate if the fuel is low or if battery is low on voltage. It will not use battery power that will be needed to start car,and will not use fuel that may be needed to get you to a garage. If these two things are not the reason. See if you can hear it working,from under bonnet N/S in front of Battery and Fuse box. It should work on its own every time you start engine,when temperature is below 15deg itisme
Post #444748 Tue Dec 09 2014 9:54am
Gornal Hills
Hi all, just to say it fired up yesterday with no smoke at all Very Happy lovely warm cabin after a couple of miles. Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #444990 Thu Dec 11 2014 9:42am
simple1
Still get Bodsy round then you can have a nice warm cabin when you get in Bow down best thing about FullFat is that it comes with remote and also timer facility all of which can be added to a Sport I believe. Rolling with laughter 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #445071 Thu Dec 11 2014 11:52pm
harrygh60
Fuel Burn Heater
Yes and all for a Suppliment of £!025, when ordered from new. But Main agents say it cant be done after market. Yet i had mine done By Indie for Activation of software £50. And i fitted the rest for around £180. Rolling with laughter Well worth £230,Not £1025 to have a nice warm car in the morning Thumbs Up itisme
Post #445084 Fri Dec 12 2014 9:25am
