![]() | Home > General > FBH Activation help ?? |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, due to the cold weather recently I thought my fbh may of fired up but afraid not, what's the basics for helping it along, cheers |
Thanks for the reply, is this done by disconnecting a certain plug or wire ?? or at least worth a try |
mad-dafty Member Since: 28 Oct 2013 Location: Glasgow Posts: 298 ![]() ![]() ![]() |
I think there is mention of restarting the FBH in this thread mate.... |
You know where I am if you need me. |
Cheers Bodsy, i'll give it a go but if no joy i'll be req your assistance |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
It will not opperate if the fuel is low or if battery is low on voltage. It will not use battery power that will be needed to start car,and will not use fuel that may be needed to get you to a garage. If these two things are not the reason. See if you can hear it working,from under bonnet N/S in front of Battery and Fuse box. It should work on its own every time you start engine,when temperature is below 15deg itisme |
Hi all, just to say it fired up yesterday with no smoke at all |
Still get Bodsy round then you can have a nice warm cabin when you get in |
Yes and all for a Suppliment of �!025, when ordered from new. But Main agents say it cant be done after market. Yet i had mine done By Indie for Activation of software �50. And i fitted the rest for around �180. |
