![]() | Home > Faults & Fixes > EPB Code U200201 |
g8lmh Member Since: 04 Jul 2013 Location: Lancaster Posts: 67 ![]() ![]() ![]() |
Hello guys.
Cheers.
Broken wire at the rear of the car, common issue |
Cheers Mikey.
Nothing to do with the actuator.
Can a regular garage undertake the loom renewal. THis wiring loom travels from the switch (Centre Console) to the module (Aft Left Side, Wheel Arch)? Any help would be great. Is it a big job? Long run? How many hours? |
Just been informed this could be caused bya burnt out relay in rear of car? Any idea's? |
Have you checked the wiring to the switch? |
To be honest Im not 100% how to do. I changed the switch, I have not checked wiring to module from switch. Is it easy? |
If you can work a Multimeter, and read a wiring diagram, then yes |
Aye.
rich_sargie Member Since: 08 Sep 2014 Location: hull Posts: 150 ![]() ![]() ![]() |
Put the car in off-road mode, remove key, wait for car to go to sleep. Go to passenger side, rear wheel. At about 2 o'clock on the wheel just behind it is a piece of plastic. Pull it down and behind it is 2 loom connectors. Using a torch to see pull and tug lightly on each wire until you find one that comes away in your hand. Or unplug the connectors and inspect the pins. 90% it's 1 or 2 wires very rarley the plug. not to sure but it's usually the first plug and it's the red, the black, and green or yellow. Iirc. |
Cheers.
Half achieved.
