Home > General > Dash board like a Christmas tree help?
Lewis
United Kingdom 2008 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I just had a call from the missis who's out in the car just now, she told me heaps of warning lights have appeared on the dash such as ABS, Headlight direction, traction control symbol and a parking brake warning too? Just wondering if any of you guys could shed some light on this - how can all these thing come up at the same time? I've read about a bad battery sometimes causing these issues? She's just texted me a picture as attached.
Post #442255 Tue Nov 11 2014 9:50pm
JamesRoberts
United Kingdom 2005 Range Rover Sport TDV6 SE Cairns Blue
Hi mate, read your post a few minutes back. Whilst looking for a completely different issue (brake light switch how to), I noticed someone replying to that they had a Christmas tree issue related to that. Apparently a £15 fix.
Post #442260 Tue Nov 11 2014 10:16pm
Dan2020
Just ordered one from ebay following on from your MPG post James, £10.90 delivered on Thursday and allegedly its OEM! we shall see.......
Post #442264 Tue Nov 11 2014 10:41pm
Lewis
Many thanks guys just ordered a new switch too hopefully that'll be it
Much appreciated
Lewis Thumbs Up
Post #442265 Tue Nov 11 2014 11:02pm
Lewis
Thanks again for the help James fitted the new switch and all is well no more lights and everything working, I ended up ordering a genuine part £22 off ebay Im sure the others on offer will be fine as well. Also I had a look inside the old switch and sure enough signs of arcing inside as photo attached.
Many thanks again Thumbs Up
Post #442482 Thu Nov 13 2014 5:20pm
Lewis
Strangely the lights returned today during normal driving? same symptoms as before however they have gone off again, any ideas what might cause the lights to come on and go off intermittently? also found out there is a second brake light switch for the cruise control any ideas where that is? cheers
Post #443026 Wed Nov 19 2014 8:37am
D12TYJ
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
Sounds like a weak battery, if not then has to be the alternator.
Carry out a voltage check on both just to be sure.
Halfords and other garages do free battery checks, maybe worth a try popping down and getting it checked.
Post #443039 Wed Nov 19 2014 10:31am
simple1
It's usually the cruise control switch which causes the HDC fault light to come on. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #443073 Wed Nov 19 2014 6:37pm
Lewis
Cheers again for the replys, so where is the cruise switch? Is it on the steering wheel its self? I did notice the cruise didn't work a couple of times coming up from Glasgow a couple of weeks back
Post #443099 Thu Nov 20 2014 12:17am
The cruise switch is in the brake pedal switch. The switch has two operations- the initial movement disengages the cruise, then the switch illuminates the brake lights. 2012 SDV6 - it's missing a couple of cylinders
Post #443125 Thu Nov 20 2014 9:53am
