Home > General > Dash board like a Christmas tree help? |
JamesRoberts Member Since: 02 Oct 2014 Location: Hampshire Posts: 116 |
Hi mate, read your post a few minutes back. Whilst looking for a completely different issue (brake light switch how to), I noticed someone replying to that they had a Christmas tree issue related to that. Apparently a £15 fix. |
Tue Nov 11 2014 10:16pm |
Dan2020 Member Since: 24 Oct 2014 Location: Nottinghamshire Posts: 12 |
Just ordered one from ebay following on from your MPG post James, £10.90 delivered on Thursday and allegedly its OEM! we shall see....... |
Tue Nov 11 2014 10:41pm |
Lewis Member Since: 04 Jun 2014 Location: Aberdeen Posts: 26 |
Many thanks guys just ordered a new switch too hopefully that'll be it
Tue Nov 11 2014 11:02pm |
Thanks again for the help James fitted the new switch and all is well no more lights and everything working, I ended up ordering a genuine part £22 off ebay Im sure the others on offer will be fine as well. Also I had a look inside the old switch and sure enough signs of arcing inside as photo attached.
Thu Nov 13 2014 5:20pm |
Strangely the lights returned today during normal driving? same symptoms as before however they have gone off again, any ideas what might cause the lights to come on and go off intermittently? also found out there is a second brake light switch for the cruise control any ideas where that is? cheers |
Wed Nov 19 2014 8:37am |
D12TYJ Member Since: 01 Sep 2014 Location: London Posts: 183 |
Sounds like a weak battery, if not then has to be the alternator.
Wed Nov 19 2014 10:31am |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
It's usually the cruise control switch which causes the HDC fault light to come on. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Nov 19 2014 6:37pm |
Cheers again for the replys, so where is the cruise switch? Is it on the steering wheel its self? I did notice the cruise didn't work a couple of times coming up from Glasgow a couple of weeks back |
Thu Nov 20 2014 12:17am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
The cruise switch is in the brake pedal switch. The switch has two operations- the initial movement disengages the cruise, then the switch illuminates the brake lights. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 20 2014 9:53am |
