![]() | Home > Maintenance & Modifications > Side Vent Difference - 06-09 vs 10+ |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 ![]() ![]() ![]() |
Morning,
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
I think you can buy some lookalikes that fit over the wing. |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Do you have a pic of the ones you would like - I've seen almost every 10MY plus - replicated on EBay - they are made to fit 2005 - 2009 pre facelift |
powerful uk
I think I would put the £125 towards new wings In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
If you fancy a cut and shut bodge job there are some red edition ones for sale on this forum
I know that the 10-12 do not fit earlier models, the question was does anyone know the physical difference in size? Im just trying to work out the level of work that would be required if this option was chosen.
If your prepared to mod the original wing then that may be an easier option |
I don't know if I have the balls to start messing with the actual wings. My DIY skills aren't great!!
RonyTed Member Since: 03 Feb 2013 Location: Cannock Posts: 17 ![]() ![]() ![]() |
Hi, yes on the early vents the rear mesh and blades can be easily removed from the outer frame by releasing the retaining clips. Don't how much modification would be required to to fit the later mesh and blades to the early outer frame, could be interesting, keep us posted. |
Hmmm.....
Peachy, He will not be happy until he has a fully front update, wings, bumper, grill and lights, |
No Darren, the 2014 wings will not fit |
