![]() | Home > Maintenance & Modifications > Another fault |
Check your brake bulbs. Also the brake pedal switch. Be worth checking the battery when cold before and after starting to see what the alternator is doing too. 2012 SDV6 - it's missing a couple of cylinders
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
Ok so ive just checked the battery which i had tested and was told was fine, its a Bosch s3 013 90ah 720CCA . now is it just me or is the CCA not enough, reading other posts on here im thinking it should be 900cca |
Diesel should be 90Ah 825A. 2012 SDV6 - it's missing a couple of cylinders
So that battery is not powerful enough and could be my problems on these cold mormings.. Im looking at a bosch s4 battery or the s5 are they any good ?. |
When I replaced my battery I just went to LR and bought from them. That was before the new, more expensive, AGM ones though.
So from the size battery you mentioned mine being a bosch s3 90ah 720cca is way to small am i correct in saying that |
It would appear to be, yes. 2012 SDV6 - it's missing a couple of cylinders
