Home > Maintenance & Modifications > Another fault |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Check your brake bulbs. Also the brake pedal switch. Be worth checking the battery when cold before and after starting to see what the alternator is doing too. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 06 2014 11:18am |
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 |
Ok so ive just checked the battery which i had tested and was told was fine, its a Bosch s3 013 90ah 720CCA . now is it just me or is the CCA not enough, reading other posts on here im thinking it should be 900cca |
Thu Nov 06 2014 12:40pm |
Diesel should be 90Ah 825A. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 06 2014 1:35pm |
So that battery is not powerful enough and could be my problems on these cold mormings.. Im looking at a bosch s4 battery or the s5 are they any good ?. |
Thu Nov 06 2014 1:38pm |
When I replaced my battery I just went to LR and bought from them. That was before the new, more expensive, AGM ones though.
Thu Nov 06 2014 6:40pm |
So from the size battery you mentioned mine being a bosch s3 90ah 720cca is way to small am i correct in saying that |
Thu Nov 06 2014 6:42pm |
It would appear to be, yes. 2012 SDV6 - it's missing a couple of cylinders
Thu Nov 06 2014 11:04pm |
