Home > Maintenance & Modifications > Another fault
Wayneclarke
Another fault
Hi guys, been having messages on start up special programmes off mainly in the mornings when the car is cold I was told it proberly the battery so yesterday I had the battery checked and was told it's good 85% life. So this morning I've come to work +3 degrees outside and now I get a new message HDC system fault!!! Can anyone help and shed some light as to what these messages mean this is my first RRS so I have no clue.
Post #441652 Thu Nov 06 2014 4:00am
Check your brake bulbs. Also the brake pedal switch. Be worth checking the battery when cold before and after starting to see what the alternator is doing too. 2012 SDV6 - it's missing a couple of cylinders
Post #441698 Thu Nov 06 2014 11:18am
Wayneclarke
Ok so ive just checked the battery which i had tested and was told was fine, its a Bosch s3 013 90ah 720CCA . now is it just me or is the CCA not enough, reading other posts on here im thinking it should be 900cca
Post #441707 Thu Nov 06 2014 12:40pm
Diesel should be 90Ah 825A. 2012 SDV6 - it's missing a couple of cylinders
Post #441717 Thu Nov 06 2014 1:35pm
Wayneclarke
So that battery is not powerful enough and could be my problems on these cold mormings.. Im looking at a bosch s4 battery or the s5 are they any good ?.
Post #441719 Thu Nov 06 2014 1:38pm
When I replaced my battery I just went to LR and bought from them. That was before the new, more expensive, AGM ones though.
The old battery appeared to be from a car rather than a RRS (it was significantly smaller) and was probably the reason that the alternator failed a month later... 2012 SDV6 - it's missing a couple of cylinders
Post #441760 Thu Nov 06 2014 6:40pm
Wayneclarke
So from the size battery you mentioned mine being a bosch s3 90ah 720cca is way to small am i correct in saying that
Post #441761 Thu Nov 06 2014 6:42pm
It would appear to be, yes. 2012 SDV6 - it's missing a couple of cylinders
Post #441796 Thu Nov 06 2014 11:04pm
