![]() | Home > General > 2010 Sport Steering column locked & vehicle wont start. |
aljo Member Since: 13 Jun 2006 Location: West Sussex Posts: 3243 ![]() ![]() ![]() |
is it keyless entry ? |
Kidneywiper Member Since: 07 Feb 2011 Location: England. Posts: 16 ![]() |
Yes, keyless entry. |
probably battery going flat on your key
All new batterys fitted in both keys. Still no better. |
do you get an error message saying key out of range or not found etc ? |
The only message showing is steering column locked. |
may be an idea to see if any fault codes are showing and do a "hard reset" |
merlin1 Member Since: 16 Sep 2009 Location: cornwall Posts: 110 ![]() ![]() |
Try moving steering wheel slightly side to side while pressing the start button ,sometimes the steering wheel is to tight and the steering lock jams . |
Needed a new instrument pack to cure the problem. Known fault with a L/R bulletin to go with it apparently ! ! |
peterg1965 Member Since: 20 Sep 2014 Location: Lancashire Posts: 81 ![]() ![]() ![]() |
How much did that cost? Range Rover - 4.4SDV8 Autobiography - Corris and Black
£450 for the intrument pack & 2hrs labour cost at the dealer plus vat. |
Blimey, that must have hurt. Range Rover - 4.4SDV8 Autobiography - Corris and Black
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
Anyone knows the bulletin number? |
diamond71 Member Since: 24 Nov 2014 Location: horsham Posts: 25 ![]() ![]() ![]() |
would be great to get that bulletin number, I have the same problem 2010 model |
