Home > General > 2010 Sport Steering column locked & vehicle wont start.
Kidneywiper
Hi, my 2010 sport is stuck in the yard. It will not start & is showing steering column locked on the dash. Any ideas guys ?
Post #438722 Tue Oct 07 2014 3:22pm
aljo
is it keyless entry ?
Post #438734 Tue Oct 07 2014 4:34pm
Kidneywiper
Yes, keyless entry.
Post #438735 Tue Oct 07 2014 4:36pm
aljo
probably battery going flat on your key
hold your key under the steering cowling plastic covers see if it picks up the signal
Post #438736 Tue Oct 07 2014 4:38pm
Kidneywiper
All new batterys fitted in both keys. Still no better.
Post #438737 Tue Oct 07 2014 4:40pm
aljo
do you get an error message saying key out of range or not found etc ?
Post #438738 Tue Oct 07 2014 4:43pm
Kidneywiper
The only message showing is steering column locked.
Post #438767 Tue Oct 07 2014 7:55pm
aljo
may be an idea to see if any fault codes are showing and do a "hard reset"
Post #438780 Tue Oct 07 2014 9:24pm
merlin1
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Ref steering wheel
Try moving steering wheel slightly side to side while pressing the start button ,sometimes the steering wheel is to tight and the steering lock jams .
Post #439121 Sat Oct 11 2014 11:42pm
Kidneywiper
Needed a new instrument pack to cure the problem. Known fault with a L/R bulletin to go with it apparently ! !
Post #440044 Mon Oct 20 2014 7:25pm
peterg1965
United Kingdom 2012 Range Rover Sport SDV6 HSE Buckingham Blue
How much did that cost? Range Rover - 4.4SDV8 Autobiography - Corris and Black
MY12 SDV6 HSE - Buckingham Blue and Ivory leather - NOW GONE
Post #440101 Tue Oct 21 2014 1:14pm
Kidneywiper
£450 for the intrument pack & 2hrs labour cost at the dealer plus vat.
Post #440105 Tue Oct 21 2014 1:39pm
peterg1965
Blimey, that must have hurt. Range Rover - 4.4SDV8 Autobiography - Corris and Black
Post #440155 Tue Oct 21 2014 8:16pm
CUCO
Spain
Anyone knows the bulletin number?
Post #440180 Wed Oct 22 2014 11:08am
diamond71
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
would be great to get that bulletin number, I have the same problem 2010 model
Post #443530 Mon Nov 24 2014 4:58pm
